24P JVCPRO footage when in premeire pro 2.0.. turns into 59fps at DVinfo.net
Old September 5th, 2007, 01:21 PM   #1
I know this is more then likely an easy fix, like the pulldown method?
I recorded video in hd24p of a 3 min green screen spot.. When played in media player or any player it is fine.. Perfect frame rate and audio is in perfect sync.
When I drag that mpeg file into adobe premiere pro 2.0 it converts the 24fps clip to 59.94fps.
Audio is off, and the clip is of course playing at 60fps..
How do I fix this?
Drew Hyttenrauch is offline   Reply With Quote
Old September 6th, 2007, 08:06 PM   #2
Try installing the presets and create a new project based on the JVC 24p HDV
http://www.adobe.com/support/downloa...jsp?ftpID=3409
tup
Tup Wright is offline   Reply With Quote
Old September 6th, 2007, 09:28 PM   #3
Time code Brocken
Premiere pro have a problem with the timecode broken.
The video capture is bad when:
There is a drop (audio is broken and video continue captured)
When the file is indexated and created, premiere asignet the bad settings: 59.97 , not 24p.
Recaptured with the Capvhs o the HDlink Cineform m2t file. Import the premiere pro´s Timeline.
Voalá!
4:3 don´t go!!
Oscar Honorio Pantoja is offline   Reply
