SSE in HD200series? at DVinfo.net
Old January 15th, 2008, 02:00 PM   #1
SSE in HD200series?
Hi guys
Simple enough question I guess. Does the 200 series suffer from the SSE problems the 100's suffer from? Its the same split chip design is it not...
Old January 19th, 2008, 07:10 AM   #2
Anybody experience of the 200 series with any problems?? Or do I take it from this that it doesn't ?
Old January 19th, 2008, 09:52 AM   #3
Consider it a non-issue.
I've never seen it, despite pushing the (200) camera to it's extreme low light limits, which is the only time it will show up in a properly setup and upgraded 100 series camera. I've heard reports of people still seeing it on 100 series cameras that are firmware upgraded, but then only in very poor lighting conditions. I couldn't induce the effect in my experimentation in these conditions (gain, slow shutter, wide open). I also have worked with 100's and 110's and never seen the problem in many hours of real world shooting.
Yes, the chip on all these cameras is split in processing, but it's nothing you should be thinking or worrying about. It is the best way to accomplish what they are trying to do, and common to other pro grade cameras as well. The only issue was "tuning" the processing for stressful lighting conditions when the 1st gen cameras were first released.
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old January 19th, 2008, 10:58 AM   #4
Thanks for the reply....that is reassuring !
Old January 19th, 2008, 12:50 PM   #5
The 200 series do not have this issue, the chip scanning process is the same from the 100 series, but the firmware is much more efficient and eliminates the SSE in all light situations. Has I understood from a JVC thechnician, the 100 series analyzes the image using 3 parameters to correct the split, the 200 uses much more parameters (I don't remember exactly how many).
Diogo Athouguia is offline   Reply
