Confused - Can JVC gurus HELP??? Can I use HD100U model in a PAL country?? at DVinfo.net
Old February 8th, 2008, 06:30 PM   #1
I'm a bit confused & don't want to make the wrong investment.
Firstly, I shoot events on DVX and Canon A1, however the hand-held form factor has some limitations especially when I'm shooting without a tripod (which happens often due to time constraints.) After a year of deliberation regarding which ENG style camera I should choose, I decided to go with the JVC HD110 because of the real mechanical lens and shoulder mount form factor.
My dilemma is:
1) I can buy the US version "HD110U" for $2000 less than I can source a European version "HD111E". I believe that the camera is switchable between PAL & NTSC but I was wondering if there are any other problems I might come across if I'm solely shooting PAL on a camera designed for USA/NTSC countries.
2) Also, is the camera 720P 24frames native regardless of which country it is being marketed for?
Thanks for any help,
James :)
James Thirston is offline   Reply With Quote
Old February 8th, 2008, 06:43 PM   #2
HD is ntsc/pal agnostic. It's HD.
Old February 8th, 2008, 07:24 PM   #3
Hi James,
I think there is a difference where you cant record back to camera with that model. I have the HD111E
Are you in Perth WA?
Dennis Robinson
G5, , 30 inch display, FCP6 Studio 2, JVC-GYHD111
Dennis Robinson is offline   Reply With Quote
Old February 8th, 2008, 07:45 PM   #4
PAL/NTSC frame rate compatibility is still a tiny bit of an issue in most practical applications.
Antony Michael Wilson is offline   Reply With Quote
Old February 9th, 2008, 01:35 AM   #5
James,
Brian is somewhat right. when he said HD is ntsc/ pal agnostic, he meant HDV. It can now be edited in most NLE's, the problem is when you decide what format to output it depending on your country's broadcast standard. This is decided in you NLE.
I'll reverse your situation. I got my HD100 couple of years ago but its the E version, meaning it cant record in VTR mode due to some stupid european tax law.
BUT I live in NTSC land. I had no problems. Just use the modes available in HDV and your ok.
Ted
Old February 9th, 2008, 03:18 AM   #6
Case closed - the US version it is then!!
Thank you all especially to Ted for providing a hands on explanation.
By the way I'm familiar with the law you are talking about which limits the HD-100E firewire input from being able to accept video in, so JVC had to create 2 models at two price points, however the U model has no such limitation yay!!
Dennis, I'm not in Perth but Sydney... I was in a hurry when I was filling out my forum application - opportunity to set it right now I guess ;)
Thanks again!
JT
