successful FCP native HDV capture - Page 2 at DVinfo.net
Old April 27th, 2008, 07:54 PM   #16
Originally Posted by Charles Barreto View Post
not to take this out of subject...but does anyone know where I can find minimum specs for a G5 running Final Cut Pro to edit my GY-HD100 footage?
Before I got into HDV i was able to edit all day and night using my 2GHz Intel Core Duo MacBook Pro with FCP 5.1.4. Now with my JVC HDV footage, I am chug chug chugging along and it is killing me. I am not looking for something like super high end...I just want at least to do two layer video without crapping my computer...mabe I would need a cheapy BlackMagic card?
Any ideas?
Your computer is plenty fast enough. The weak link in your speed chain is probably your HD. Where are you storing your media?
Tim Brown
www.conceptwax.com
Tim Brown is offline   Reply With Quote
Old April 27th, 2008, 09:16 PM   #17
I got all my media in an external Lacie Terrabyte drive...I've also tried in smaller 250GB drive modules via firewire...but it chugs
Charles Barreto is offline   Reply With Quote
Old April 27th, 2008, 10:28 PM   #18
so the clips are not chopped up into many clips? Is this is true, then this would be the way to go.
All right, I did a test with one full tape. Not a single broken clip, not a single dropped frame. Just to be thorough I switched to other applications during the capture, ran a couple of SQL queries, refreshed a few Safari tab, still not a dropped frame. And the clip in interpreted correctly at 23.976 fps. I'm very, very pleased.
What would make Premiere better or equal to FCP?
In my opinion Premiere has now the upper hand. At the video level we have:
- multi-format editing. FCP is bound to QuickTime only. Premiere works directly with .m2t file, other mpeg variants and others. You can pretty much convert everything to QT but this option makes your life easier.
- Image sequence are supported. A feature important for VFX work.
- Multicamera editing. Synch of multiple clips is actually more flexible in Premiere as it supports synchronization via markers.
- Sound. FCP is still pretty primitive when it comes to sound processing. Premiere allows you to work with surround sound 5.1 in the timeline and supports VST plugins.
- Dynamic link with AE. Copy a piece of the timeline, switch to After Effetcs, paste in it, apply effects, now Premere and After Effects are updated in real time. This was, BTW, the main reason for me to switch. To get full compatibility with my HD100 is icing on the cake!
Finally, I can say goodbye to the DVHSCap/MPEGStream clip workaround.
There are many other features but I'll cover them in another place, I don't want to "highjack" the thread too much.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old April 28th, 2008, 12:06 AM   #19
Hi Paolo.
I've been looking at the Adobe Suite for a while. So your experiences are of great interest. I'll start a new thread in the Mac forum where I'll have a couple of questions.
David Knaggs is offline   Reply With Quote
Old April 28th, 2008, 07:30 AM   #20
Hello Charles,
You may want to look into a CalDigit Express card along with a supported drive. I suggest something from G-Tech.
Tim Brown
www.conceptwax.com
Old April 28th, 2008, 09:16 AM   #21
Originally Posted by David Knaggs View Post
Hi Paolo.
Send us the link so we I can take a look at it...interested also in the native plug-in capabilities.
Hello Charles,
but I do need a G5 for this right?
Old April 28th, 2008, 10:49 AM   #22
... but I do need a G5 for this right?
The Express card is for the MacBook Pro.
Tim Brown
www.conceptwax.com
Old April 28th, 2008, 05:57 PM   #23
Hi Charles.
Here's the link:
http://www.dvinfo.net/conf/showthread.php?t=120462
Old May 6th, 2008, 08:27 AM   #24
I'll also note that the 3.2 release of Prem Pro can also handle corrupt Mpeg2 streams from drop outs, really bad ones. Prem can go thru and flag bad frames, then resync after the bad frames so the audio stays locked. thats really impressive. compare that to FCP which seems to barf at one bad bit of data, while Prem Pro will just take it in and run with it.
Steve Oakley is offline   Reply With Quote
Old May 6th, 2008, 09:39 AM   #25
True, I noticed that Premiere actually creates a log in the Info window showing the possible data/timecode breaks. Those entries in the log can the be used to just to the location without having to scrub manually.
Demo Reel
Old May 6th, 2008, 09:50 AM   #26
This is promising. I hope Apple follows suit with the next version of FCP.
Tim Dashwood
Old May 6th, 2008, 12:16 PM   #27
I hope all you guys don't make the switch...the FCP help pool on here just won't be the same!
Funny, I deliberately made the switch from Prem Pro on the PC to FCP on the Mac due to poor behaviour, although to be fair that was mainly down to the PC.
Still, interested in the link up between AE (which I'm keen on getting my hands on) and the entire suite.
I tend to use Logic Pro for audio so not really sure if this favours one NLE over the other.
I guess apple won't close the loopholes associated with the HD100, but I'll stick with FCP for some time. I made the switch from Cubase to Logic and it was almost like using a different language....frustrating indeed.
David Scattergood is offline   Reply With Quote
Old May 6th, 2008, 01:31 PM   #28
David, I still have FCP but the lack of support by Apple for some essential features, like image sequences, mpeg, and integration with After Effects made me finally cross the threshold. I just remembered that when I got my HD100, winter 2005, a friend of mine, with Premiere on a PC, was able to capture footage right away while for the past 2 years we have gone from struggle to struggle with FCP. We got the "A" upgrade that was supposed to improve things with the NLE, we got endless updates, it's still broken. I tried Premiere and I was surprised how easy it was to pick up. The downside of Premiere is the performance. I's not as optimized as FCP to run with non-specialized hardware, but it's getting there.
At the end of the day I just use what tool makes sense for the job and right now Premiere is a very good solution for HD100/250 owners and the integration with After Effects makes post work and color correction really easy.
Demo Reel
Old May 6th, 2008, 02:12 PM   #29
Absolutely Paulo - in fact I've just had my HD100 back from JVC - the (A) upgrade, latest firmware and some [unknown??] motherboard replacement...tried to capture natively and still no luck (although this was on footage captured 'pre-op' if that makes any difference)!
The workarounds are often a ball and chain to creativity - you just want it to do what it says on the tin, not fiddle with sub programs.
Be interested to see what apple does over the next year or so - I had Prem Pro down as losing the NLE battle (and I believe the BBC have bought into FCP in a big way).
Had I AE and critical colour programs I'd be tempted to take a look again at Prem. Is much of the Adobe suite rocky for intel macs?
Old May 6th, 2008, 07:22 PM   #30
Well, I've been using AE CS3 for a while and it runs just fine. I started using the rest of the Master Series recently but it seems pretty stable.
Demo Reel
