-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   Tripod Plate Worth Getting (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/122679-tripod-plate-worth-getting.html)
Taylor Brush May 29th, 2008 04:31 PM
I know there had been some discussion about the tripod plates on here, but I just wanted to say that I bought the Sony U14 and it perfectly balances my camera on the tripod. It makes all of my camera moves more fluid and stabilizes it wonderfully. It was painfully obvious to me when I mounted the camera directly on the tripod that it would not work well without it. I have the Miller 20 tripod and it wouldn't counterbalance right without it. Now, it works perfectly. I just wanted to throw this out there for the people who might be thinking about buying the JVC or Sony plates, but were on the rails whether it was worth it. It is.
Robert Castiglione May 29th, 2008 06:06 PM
I have been wondering about this for some time.
Do you mean the VCT-U14 Quick-Release Tripod Adapter?
Does it attach securely to the camera body so that there is no movement and also do you need to buy any other bits and pieces?
Thanks for your post.
Rob
Corey Williams May 29th, 2008 08:38 PM
You can read through this post and get a lot of information about this setup.
http://dvinfo.net/conf/showthread.ph...0+tripod+plate
I followed the directions of this thread and bought a vct14 off ebay for $90.
I then bought betacam parts that contained the v-wedge off ebay for $12. Basically, I got a tripod plate for about $125. Also, I i rolled a piece of foam into a 2 inch diameter and wrapped tape around it. I placed this at the back of the plate in the space where the camera hangs over the plate. Without being able to latch onto the back of the plate is was only being supported by the front of the camera. I did this to give it more stability. I'll post pics is anyone is interested.
Alex Humphrey May 29th, 2008 08:43 PM
2 Attachment(s)
I balanced mine out with an extra manfroto tripod mount/plate that I had laying around on my shelf. It works fine.
I would prefer the tripod plate though since it probably locks in better and won't slide forward out and fall on the ground.... I bet there is a good way to secure the tail end of the camera to the plate to help cut down on the wiggeles while around 80mm.
Jim Andrada May 29th, 2008 10:09 PM
I have it and I like it. It latches very securely and it mounts to the camera firmly. With an AB battery on the back plus a firestore on top it doesn't rock around at all. No complaints.
Taylor Brush May 30th, 2008 05:16 AM
Alex has the right idea, but it is still not completely balanced. From you pictures, you are putting the weight of this camera on this thin plate hanging well away from the center of the tripod, which could cause it to move quite a lot.
I have used cameras with tripod plates all my career, but never fully realized, I guess, what it was doing. When you shoulder mount the camera, you are balancing it in the middle, so that the weight of the lens and the weight of the AB battery are matched. Putting the camera on the front plate does not give it enough stability to balance this weight and it makes the weight uneven. When you use the plate, you are moving the weight from the uneven front plate to the middle. The shoulder pad of the camera, the actual balanced middle with a battery attached, is now directly above the head of the tripod, which is where there is the most stability.
Also when you shoulder it, you are giving it two points of stability: your shoulder and your hand on the lens. One does not do it for this camera because of the weight and the length, so the tripod plate adapter gives it that two point stability and spreads the weight out evenly.
As far as parts needed, my camera came with the plate triangle, so I didn't have to buy that. I just bought the "Sony VCT-U14 Quick-Release Tripod Adapter" off B&H for about $200. If you don't have that triangle, you can do as Corey did and try to find some spare parts like the triangle. I tried to order the plate off eBay, but I found that there are a lot of mislabeled plates selling as the JVC. I ended up getting a completely wrong plate. Although I got a refund, it was a hastle...
Dennis Robinson May 31st, 2008 06:59 AM
Rob
Hi Rob,
The tripod quick release plate has got to be the best $360 i have spent. God knows what people would do without one. It is as rock solid as it gets.
Regards,
Dennis Robinson
Robert Castiglione May 31st, 2008 07:03 AM
Thanks Dennis.
I just bought one.
Rob
Dennis Robinson May 31st, 2008 07:13 AM
Originally Posted by Robert Castiglione (Post 886180)
Thanks Dennis.
I just bought one.
Rob
Hi Rob,
I just shot you an email.
Claude Mangold June 5th, 2008 10:23 AM
3 Attachment(s)
I have a Vocas rail support with integrated v-shoe (pix 0297) which screws on neatly in place of the standard jvc v-shoe which came with the camera (pix 0299). I just use an old sony U14 plate bolted on a heavy manfrotto tripod plate (pix 0300) which slides in the head until the correct balance is found (depends on what's on the cam: HD100, mini35, battery or no, etc.)
Vocas rail support is really useful and quick, so is Vocas mattebox. Vocas followfocus sucks.
Marc Colemont June 6th, 2008 02:02 AM
I use a Leo BeBob plate.
This way I can connect external monitors, my zoom remote on the tripod without ever to need to disconnect anything when taking the camera from the tripod. Works very well for Live events when you need to run and shoot sholder mounted and on tripod without loosing time.
And with the counter part on the camera, when you place the camera on the floor, it gives a good angle shooting without the need to place something underneath your camera.
Robert Castiglione June 9th, 2008 05:33 PM
Vocas Rail Support
Hi Claude,
Concerning the Vocas rail support, it is of interest to me because of the integrated V mount.
What model number is if for the JVC?
Many thanks
Rob
Adam Letch June 9th, 2008 08:47 PM
Same here
though I ran into a operator in Perth City, shooting a 251 with a 2/3inch lens, and mattebox, he was using the rails off a Sony Betacam bought second hand and turned upside down. Only wish I could remember which model it was, because this was my baine with the Chrosziel 450 mattebox for the HD100, can't use the Vmounts, and I also ordered the JVC Vmount tripod plate which is basically useless unless I don't use my mattebox, which for outdoor events at least is just not going to happen.
What's with Chrosziel anyway, there website has basically not been up for a year now, for such an expensive product, I remember at one point seeing a new baseplate for the Chrosziels so you could use Vmounts, but that was a year ago as well.
Claude Mangold June 9th, 2008 11:25 PM
Vocas base plate
Rob, Adam,
From the Vocas user manual, I gather it's basplate 7a, item nr. 0350-0001. But before ordering, double-check with them. They respond quite quickly to emails.
I got this in an exchange from my vendor , Visuals in Geneva, after finding out that the baseplate "required" by vocas for this cam series (I believe it was model 7f) is totally useless: not stable, screws impossible to reach, no v-shoe etc.
When I look at it carefully, it appears that the two rear screwholes were not factory drilled. So this may have been specifically adapted for the GY -HD series by Visuals. I have detected no parts number on the plate itself.
The plate is super-useful because the mattebox, followfocus and rails can just be snapped on in one unit. When I use this camera myself, it's mostly for experimental films and location scouting, so I'm happy to have something that's ready quickly, even if the followfocus sucks a bit. But my DPs also like the mattbox with those integrated eyebrows, and it fits no prob on cine primes with the mini 35.
Vocas represents the best and the worst.
Robert Castiglione June 9th, 2008 11:59 PM
Life is so tiring sometimes. The amount of research required to get exactly the right bits and pieces for something as inherently unexciting as a matter box seems quite disproportionate.
Sadly, my slackness in this regards means that I have a number of useless bits of this and that product around my studio.
Rob
Claude Mangold June 10th, 2008 12:08 AM
A helpful vendor goes a long way, especially in places like Geneva where there is no film industry and there isnt'even a set of cine primes in stock locally.
in Berlin things are much easier, you can try out combinations, test stuff etc.
As a director, I use quite a few odd things like special lenses, oddly constructed dollies etc, and that's much easier in Berlin, that's why I live there part time. And you have lots of professionals and studios who can advise.
But even by Berlin standards this site remains a priceless resource - a big thanks to all !
Brian Mills June 12th, 2008 12:21 PM
Worth It? Many Times Over!!!!
Hey guys:
I just got my KA551U tripod plate adapter today for my Bogen 519 head and all I can say is: you HAVE to get this thing! I had spent almost $900 on that head a year ago and was never really happy with it because the moves were never very smooth and then I heard about this plate and bout it and NOW I HAVE A WHOLE NEW TRIPOD!
Now this 519 responds like a dream and moves are as smooth as lubricated glass.
Yes it was $250 bucks but, oh, oh is it ever worth it for improving your moves. I have the AB battery mount with the AB wireless receiver mount, so my rig is SUPER back-heavy (even with the JVC wide-angle adapter on the front to counter-balance). With the tripod plate screw so far in the front, the center of balance was always way off, but this plate fixes it.
So if you are on the fence about paying almost $300 bucks for a simple little tripod adapter, I wholeheartedly recommend it!
Brent Kolitz June 12th, 2008 01:08 PM
Marc -- do you have any links to more info on the Leo plates? I found some rudimentary info on their website but don't even see where to buy it in the US or how much the different versions list for. I'd also like to know what video connections are available (component hopefully?)
Marc Colemont June 12th, 2008 01:58 PM
Hi Brent,
They exist in different flavors with less or more available connections.
If you are handy with a soldering iron, you can modify the connections yourself.
Strangely the info on the Bebob website is gone? Maybe they are updating their website, hopefully not stopping the sales of the great unit.
This webiste has still some available:
http://www.marcotec-shop.de/en/produ.../detail_85.htm
Shaun Roemich June 12th, 2008 02:29 PM
Brian: I couldn't agree more! I'm using a Manfrotto (Bogen in the US) 501 head on 525MVB legs and was less than impressed with thetripod using it with my Sony PD150. Upon mounting the JVC plate and my HD200U (with AB Dionics), the rig is suddenly more than adequate again! Yes, I will invest in a more serious solution when cash on hand permits but MAN what a difference some weight and a plate makes!
Corey Williams June 12th, 2008 04:42 PM
2 Attachment(s)
This is how I added stability to back of the camera on the tripod plate. Notice the black thing at the rear of the tripod plate under the battery mount. It's just bed foam cut to size and rolled up. I wrapped tape around it and covered it in black material. I feel much better with this because the weight isn't focused on the v-wedge mount.
Shaun Roemich June 12th, 2008 05:17 PM
Corey: do you not have the rear position "pin receiver" (silver coloured, two screws, slides around the back pin on a Sony styled (ie. The JVC) tripod quick release plate?
EDIT: Never mind. Just noticed you're using a 100 series. With the 200 series, we have a place on the back "jack pack" for the "proper" pin receiver. My bad!
Alex Humphrey February 4th, 2009 06:15 PM
Well I broke down and got the JVC tripod plate. It helps, and is a better way to go. Still need to get a better tripod though. Libec 38/55 or Miller 20 is in my future. I can't see spending money on a manfrotto again, though I hear good things about the 516/519 heads and matching sticks.
Taylor Brush February 5th, 2009 06:10 AM
Alex, I own the Miller 20 and it is smooth as glass with the JVC and the tripod plate. You will not be disappointed.
Stuart Nimmo February 5th, 2009 12:23 PM
I wouldn't consider tripod work without a tripod quick release plate. It's exactly the same as the broadcast industry standard, every camera used to come with one, which means you can find them second-hand. The GY HD cameras are too long and heavy to use safely perched on a front plate only, something will give before too long. It must put a huge strain on the front screw area of the camera chassis too.
