gy100u hdv playback problems at DVinfo.net
Old July 6th, 2008, 12:44 AM   #1
help
recorded in hdv 24p,i hit the record button would get a tally light and see time code running,but now i go to play it back,and all i get is black screen,it says play in the lcd but no time code rolling and no picture
so for fun i put a tape in that was recorded in dv60i format and it plays back no problem
and i changed the setting accordingly
Mark Morgan is offline   Reply With Quote
Old July 6th, 2008, 10:40 AM   #2
mine records a frozen frame with time code running during record. Tim dashwood mentioned its a problem solved by the "A" upgrade. Is your HD100U upgraded? You can look under and see if you have the A sticker.
Old July 6th, 2008, 10:45 AM   #3
no i don't think that it is updated,but what suks is that i did 3 days of shooting on a low budget feature no time to check record,thought all was good when i didn't see any warning lights and i saw time code rolling
Old July 6th, 2008, 10:53 AM   #4
I know. even the freeze frame problem I had. It has no indicators that something is wrong while you are rolling because timecode is running only upon playback does the very long freeze frame shows. Its different from a drop out or glitch.
Heres the thread on the issue;
http://www.dvinfo.net/conf/showthread.php?t=121835
Old July 6th, 2008, 12:47 PM   #5
It looks like you'll need the 'A' upgrade reading your post...
Marc Colemont - Belgium - http://www.mc-productions.be
JVC GY-HM850's, HM890, HM600
Marc Colemont is offline   Reply With Quote
Old July 7th, 2008, 01:13 PM   #6
so your saying if i get the update on the camera,the tapes that i recorded on
will playback or are the three tapes i shot in the crapper
Old July 7th, 2008, 01:31 PM   #7
Mark,
most likely they are. My suggestion is , if you don't want to send your camera in, get a DTE solution. In other threads they said its only recorded on the tape and not on the m2ts you record on a DTE recorder.
Look at here.
http://www.dvinfo.net/conf/forumdisplay.php?f=60
Theres nNova, Firestore and also Citidisk HDV. They record the m2t files of your camera via firewire.
Ted
Old July 8th, 2008, 09:13 PM   #8
From my experience, when I had the HD100 camera which also had this problem before JVC did the update (here in Europe it was not called an A-update).
The part of the tapes which were not readable, were not readable either after the update. As it happened during recording. After the update I never had the problem again, and it worked fine since then.
Old July 10th, 2008, 02:31 AM   #9
Mark,
Look at here.
Ted
how do i go about getting this upgrade
