JVC GY-HD200u battery question
Ok, this is probably a question already answered but I can't find where so please forgive me if it is already asked and answered.
I ordered to JVC GY-HD200u for my boss and am trying to figure out the battery requirements. He needs to be able to shoot for at least 3 hours at a time (and I do to as he will let me check it out). Is the Anton Bauer Logic Series Dionic a good battery? It is here http://www.adorama.com/ABD90.html If I buy that battery, do I have to buy the extemely expensive charger too? If so, can anyone recomend a less expensive option? I'm also getting him a 35mm lens adapter and the budget appears to be pretty blown. Thank you as always for any help you can give me. I really know nothing about batteries. |
That's definitely one of (if not the) best battery money can buy. Just to give you an idea, just one of those powers my camera AND my light for about 3.5 hours of run and gun. Without the light I could probably go for 8 hours.
You could save $100 if you go with the Tandem 70 which combos as a power supply and single charger. |
That is a very good idea, but I think I'm going to go for the TITAN 70 and Trimpac 14 charger combo as the charger can be used for nicer batteries down the road. I had no idea to look for profesionaly batteries when I said I would do this. Oh, the learning curve!
When are you looking to get the 35 adapter?
I am going to be trying a converter that goes from 1/3" to Nikon and makes it so you don't need an adapter. Its also a lot cheaper than any adapters out there, under $400. I'm going to be ordering mine tomorrow and it is coming from UK, so i should have some news on it in a few weeks. I have the tandom 70 and trimpack 14 and it last 3-4 hours for me. |
I'm not sure yet, he has to decide which one he prefers. It is basically between RedRock and another now.
An adapter that goes from 1/3 to Nikon? That would be a lot better then filming the ground glass 35mm image I would think. Hmm. What is this device? It sounds perfect. |
I think i will order one tonight so i might have it end of next week, and then i have to find a lens to go with it. But the removable lens is the reason i got the HD110 over the HVX, so it seemed funny that now 35 adapters use something like this.
Here is what i got from the person that makes it: It protrudes from the camera about 15mm ( less than 5/8" ) any Nikon lens will do. It is just a lens adapter , so there is no alteration to the image size , or quality. This is a straight adapter from Nikon - 1/3" No optics , mirrors , etc. It just sets the lens at the correct Focal Depth. |
A Bayonet to Nikon mount will not give you the same results as a 35mm adaptor. It will also restrict you to almost exclusively telephoto shots.
If so what about using the mount with a relay lens that connected to a 35mm adapter? My main thing is i don't want my setup being so long, with the Fujinon and then a adapter on the front. |
Have a look at
http://www.proav.co.uk/product_info....20ac1f56a26276 Swit batteries are an excellent alternative to the more expensive IDX units. You'll find you can shoot for a whole day on 2 to 3 batteries. They offer excellent value for money when compared to major brand batteries. Obviously you'll need to order your 200 with an IDX back. As for 35mm dof adaptors, I'd recommend you avoid the Letus with this camera. It's fiddly, hit and miss, not sharp and in my opinion not suitable for the JVC. I can't speak for other units although I'd assume the same may be true due to the stock jvc lens. Until Letus bring out a direct relay I'd avoid them altogether unless you go for a P+S. Hope that helps. Stuart |
the Titan 70 and Tandum 70 are the same thing. (they just changed the names)
FWIW, I charge a Hytron 140 on a Tandum charger |
| All times are GMT -6. The time now is 08:57 PM. |
