[HDD FOCUS DR HD100] rec. files for editing on PC problem at DVinfo.net
Old December 9th, 2008, 05:07 AM   #1
Hi everybody,
I have a little problem without answers...
When I recording, with my HD111 on my DR HD100 , evera time i press PAUSE/REC, the focus HD write a new file , with a specific name (format, time, day, hour ecc.)
Finish the recording I like to edit with pc the video BUT inside the focus I foundo also more of HUNDERS files...
I love work with edius , but the same problem I have also with anothers editing programs...
I must insert any clip on the timeline...I not found any function can import any sequenze (all the hunder files) with time order ofcourse...
No problem when I have few files...I can make manualy...onx for one in the right sequence...
BUT with 50 or 100 or more...is a big PROBLEM...put one for one.
Any one have a trick ?
I try (on edius) to put al the files selected focus DIR , with the mouse-drag , inside the video timeline...and work BUT not insert with right sequenze...so a big trouble to put again in the right sequsnze manualy...
how must work with this multifiles by focus HD to insert all in time line automatic ?
THANKS!
Jimi Zanei is offline   Reply With Quote
Old December 10th, 2008, 04:47 PM   #2
Make sure the order is correctly set like oldest-on-top before dragging to the time-line.
The HD-100 does add nicely all the dates and times one after the other.
Did you change the internal date or hour of the DR-HD100 in between shots?
Other then that, looks more a question for the other part of the forum were the NLE packages are handled.
Marc Colemont - Belgium - http://www.mc-productions.be
JVC GY-HM850's, HM890, HM600
Marc Colemont is offline   Reply
