Ok, I'm resurrecting my two month old thread. After seeing the Adam Wilt DV article, the JVC looks like the best bet for me, but I'm still uncertain about the image going soft in pans.
One expert said the JVC has the cleanest implementation of HDV but you can get it to "break". Another expert complained of "nasties" and put up a pretty damning jpg. I respect both these men so I am a bit confused. I've shot some standard DV stuff of leaves panned in high-contrast daylight that seemed to "break" DV, so is this all we can expect from compressed video. I guess any GOP would make every problem worse, right? If it's a problem with only certain types of footage (leaves, water, & the like), I guess I'll have to consider it, but if every single pan goes soft and has an exaggerated motion blur to it, like the Sony I saw, did, it's not acceptable. So, please tell me does every pan cause trouble? Thanks in advance. |
The frame Graeme posted of the the tree is the worst I've ever seen. I've never had anything like that in my own work. |
I must admit it was pretty awful, but after a weekend of playing with the camera, that's the worst I got.
HDV would be fine in this regard if you saw the compression in the viewfinder, then you'd know to do another take. What would worry me is not knowing quite what it looks like until you get it back to the NLE. The other stuff I shot with the JVC looked nice though, especially after some Film Effects: http://www.nattress.com/Movies/StereoImages.mov Graeme |
Graeme,
Was your jpg. from a 24p shoot? Did 24p have less problems then 30p? Nate, Does the image softness on pans happen as much on 24p as opposed to 30p? The Sony's problems seemed less, when I increased the shutter speed. Seeing how the JVC has less problems to begin with, and has shutter speeds that can be set incrementally over it's entire range, wouldn't a very modest increase possibly rid us of the soft blur problem? Has anybody tried this? I know alot of DVX shooters use shutter speeds of 1/42 or 1/36 to help cover the stutter on pans. Would lower shutter speeds, such as these, possibly mask the soft blur problem on the JVC pans? Or make it worse? Thank you, once again. |
That frame was from 30p. I did most of my tests at 30p. I did use 24p, but not too much. I only had the camera for 2 days....
Graeme |
| All times are GMT -6. The time now is 06:02 AM. |
