would this be ok?
I have a Buffalo 500GB DriveStation Duo which has both 4 and 6 pin firewire connectors. The 4 pin is connected permanently to my laptop. The drive is turned on and off as needed and never hot swapped.
Would it be ok to connect the spare 6 pin on the drive (see http://www.buffalotech.com/images/pr...uo-back-lg.jpg for a picture) to my HD111E and then switch both devices on? This way I could keep my laptop on all the time and I am not technically hot swapping. Maybe I could also get a power isolated lead (anybody know where I can get one in the UK?) to help isolate the power. |
I'm really interested in an answer to this. I'd do a similar thing with my firewire drive if this is an option. |
I fried my JVC HD100, it cost $2800 to fix because it's the main board that's fried. Thank god for insurance. Any suggestions on where to rent a 720p deck in Australia in the meantime? I have some footage of a concert I did for free but I don't want to spend $300+ to capture footage of a concert I shot for free.
Will,
Maybe others can help as I don't have a 720p camera. I'm pretty sure most sony 1080i HDV cameras will also playback 720p footage, but I don't think it will output them through firewire (according to the manuals) - only composite/s-video as SD. Might be worth trying if you can get your hands on a sony HDV, but I don't like your chances. Like I say, maybe others can help.. |
What I didn't know about AC
I had a little JY-HD10, Was working great (you can see a clip made with it here: www.sighter.com) BlackEnd...
When I finished that shoot I went on a location to start capturing the shoot on a little iMac (the new one). When I aproach the Firewire Cable to my external HD I got this powerfull sparcks!! with smoke and everything coming out of the external HD.... (The cam busted. Would cost more to repair than what it cost) later I learned that any electronical equipement you have to link together HAS to be on the same Wall AC outlet.. The tech at my service repair told me that even if the outlets are in the same room it doesnt mean that they are on the exact same phase and if you get to link equipement via Firewire it is extremely risky to do so if they are not connected on the same wall outlet. If someone outthere have a more technical approach to explain this come forward, I just learned that and maybe I am not explaining it perfectly with my "Quebec" accent... hehe Maybe a lot of you outthere already knew that but this is for those like me who didn't... -Sighter |
Too bad people are still learning this the hard way. I know somebody who fried several firewire hard drives in the early days because he believed them when they said they were hot-swappable. I came from the old "scssi" Avid days and learned then to always power down things before unplugging, so I've avoided this problem. Manufacturers should put something in the manuals that says to power down first, I think.
Question for the techies.
Call me paranoid, but it's ok, I am.
Is there any advantage to be gained from using and isolator on BOTH ends of the equation? i.e. isolator into cam, into firewirecable ,into isolator, into computer. And what about the ferrous core magnets attached to the firewire cable. The manual wants them as close to the inputs as possible. |
It just dawned on my that Sony's betacam sp PVW video decks will blow a fuse if the unit is powered up and one plugs the remote TBC unit either in or unplugs it. So I guess the firewire issue actually has precedence in earlier video decks.
So I take back my prior sentiment almost completely. |
Thanks John!
Then what about the ferrous core magnets. Should the isolator go at the computer end or camera, or is there any difference? There is already a large sign posted (by me) at the editing desk...."POWER DOWN DUMBA**" I need these kind of reminders or I get sloppy. |
Run off battery and use a decent surge protector /power filter on all your PC and hifi gear. Use your isolator and follow the protocol (the idea of the isolator is actually to give you hot swap capability but I wouldn't risk it). That should keep everything clean and safe. |
All the firewire cables I've seen have magnetic suppressors at both ends. The point of the magnets is NOT to suppress shorts, but, rather to suppress RF interference. They won't do squat to save your firewire bus from a short.
Ahhh thanks John, I thought I was having a bad day when I tried looping the cords through tiny core's
Ive got a couple of firewirecords without magnets (unless they are built into the flat housing) so Ill go to my Bundles n More guy and get some good ones. Still gotta find one of these isolators, two if one for my laptop as well.... |
We just blew the port on our GY-HD100 with a Firestore. With these units, we are plugging and unplugging constantly. The operator may not have noticed the camera was on. I just have no idea.
Is there a cable M/M out there without the voltage pin active? Would that work. The port isolators here look like M/F adaptors. |
o.k., I think I may have blown one of my ports. One of my GY-HD 100's doesnt connect via Firewire anymore. How much is the fix?
Randy |
$1995 , I paid $1395 couple weeks ago after the discount .good luck
$2,000!!!??? are you kidding me? Well I guess im using tape. I cant pay that. I was going to get a on board HD but not now. Thanks.
[QUOTE=Randy Johnson;802612]$2,000!!!??? are you kidding me?
the same thing i said until i got the discount . |
Im not worried about my home system, I planned on getting the Firestores next year. Im more worried about blowing the port in field. If got that cable would that eliminate the poetential for that problem? I can get a 4 pin Firewire card for my home editing system too if it will help. So this is from the power in the computer? or the camera? or both?
I haven't blown my report, but I'm getting paranoid that I might!
What does it take to caputer through component? a 500 dollar card? If so, and if I blow mine, I can't see paying $2,000 for a repair. The camera is barely worth that. |
Sorry if this has been menotined. I called Firestore and they told me that the FS-4 has 2 Firewire ports 1 for shooting and 1 for File transfer. The 1 for shooting even though it is a 6 pin does not carry power. I dont know if this helps our situation or not.
Randy |
Dealer recommended a spark arrestor
I'm considering the purchase of a GY-HD200U, and my rep mentioned the fried firewire issue. He recommends using a Kramer PT-1FW spark arrestor. I'll probably velcro the thing to my Firestore. http://www.fullcompass.com/product/316180.html
No, this isn't an ad for Full Compass, I'm just buying the unit from them. While we're talking about the 200, I'm really hoping you guys can answer some questions: 1. I like what I'm reading about the HD200, it sounds like a good unit. However, I need to know if it can be tweaked to closely match a Panasonic AG-DV200p about 3-4 times a year. 2. I edit with Xpress Pro, and Avid tells me it'll accept 720p/60 from the HD200, but I can't find the camera on their list of approved devices. I read on a forum that the camera must be connected to the host firewire port instead of the Mojo during capture, but can anyone out there confirm success in getting Xpress Pro to communicate with the GY-HD200U? Were you able to batch-capture? Any tips, tricks, or warnings for me? 3. Lastly, has anyone tried putting the HD200 on a Manfrotto Fig Rig? Was it worth the expense? Looking forward to your input. thanks. tim |
I just learned my lesson. I apparently blew the firewire port on my Sony FX-1. I was using this camera as a deck (besides filming a lot with it) and constantly unplugging and plugging it into firewire ports on two different computers to capture. Any way to fix it for a reasonable price, or do I just have to send it to Sony and see what ridiculous price they quote me? I can probably just buy a new camera for whatever they will end up quoting me.... sigh
Just a note about the Kramer PT-1FW.
I got bought one from B&H and tested it with HDV signals. I shot at both HDV 30P and 24P and everything seemed to work fine. The footage looked and I didn't see any dropouts or new noise. I only shot about 2 minutes of my cat, but it does seem to have passed the signal normally. Okay, I do have to admit that I had a bit of a panic meltdown, when after I changed the scene file to 24p and the camera rebooted with drive still on, it wouldn't record to the drive anymore. I thought for sure that I'd blown the port. After much hand wringing I realized the 1394 trigger mode was never set in the new scene file. |
Same thing happened to me. I was in a hurry it was dark and I put the cable in upside down. It fried my main board in my camera. Cost me 1900.00 to get fixed so beware of doing what I did!!! the technician asked me if I had connected to a Mac. Seems there is a history with them.
Happened on an old camera of mine...right in the middle of one of my first jobs. I had to go out and buy the cheapest firewire camcorder I could find to use as a tapedeck.
I now deal with connecting the JVC like I would if I were creating a house of flimsy cards! Has anyone had experience of a blown firewire port whilst using the Kramer? I spend a bit on one and still not entirely sure whether the piece of mind is justified? On a footnote I think a monitor has recently blown on my iMac - cannot see footage on the 2nd monitor (and both the cable and 2nd monitor work ok) :( |
So I understand the part about powering off before connecting but is it necessary to power off BOTH devices before disconnecting the firewire from your cam. Someone else asked this question but no one answered.
You know I have to say this, this topic is really killing me mainly because I have 2 cameras a very small buisness its a side thing and I cant afford repairs like these. Im sorry if I rant a bit but I have been using Firewire since it came out I have swapped and swapped and never burned a port before this camera. I think the scary thing is from what I have read here and what techs have told me give me the impression that they dont know why there blowing. If its the voltage that sure a 4 pin adapter or port issolator would solve the problem because it removes the power yet they still tell us to power down even when switching the switch. I can understand why they want the 6 pin (strength and firmness) but then why cant they disable the power from within the camera? or better yet put in a fuse ro reset button? Ive heard other companys having firewire problems but not so many. After losing my ports I talked to the JVC rep about a deck asking if there would be a cheaper solution in the works maybe a deck that just played for ingestion. He told me they dont want to sell decks anymore they want to sell hard drives. Why would I buy a hard drive that is dependant on this seamilly flimsy firewire port? Im sorry im just a little frustrated right now I could be looking at spending the price of new camera (or close to it) to get my 2 cameras fixed.
thanks randy |
I've been personally involved with three different firewire drives that fried when unplugged with the power on, so I always turn off the camera or drive before unplugging the firewire cable. I know people who hotswap them all the time and have had no trouble, but sometimes it happens. I come from the old Avid scssi drive days when just looking at a drive the wrong way would fry it, so I still power down before attaching or removing the camera or drive.
Did these drives pull power from the bus or do they have a power supply?
This just happened to us this weekend with an XL-2. This is the second time it happened. After the 1st time Canon said to plug 6 pin in first then 4 pin into XL-2 then turn camera on. I suspect it to be the Firewire port on the mainboard because I just plugged my Sony TRV-27 in because I knew it worked and I brought a cable that I knew worked. No go. Tried another computer, no go, tried a 4 pin to 4 pin to my laptop, NO GO.
This is ridiculous. These manufacturers cannot even put warning stickers right on the cameras. Some one should be responsible for this because a $300 repair for the XL-2 (the second time) doing it "THEIR WAY" is just silly especially since the downtime may end up costing us some big money. They should have mentioned getting a foolproof device to make sure this NEVER happens again. I lost a nice little consumer camcorder too. |
so DON"T leave it plugged into the camera and have your IDX/AB battery installed on your camera while traveling. You might find when you get there that you lost an hour or more of run time on your camcorder.. just to keep TOPPING OFF your DTE drive. It will drain your battery dead if ignored for a day... But no one should be leaving their battery intalled on their JVC's anyway while traveling or storing. Not that i did it myself at all. And if I did, I would CERTAINLY NEVER ADMIT TO IT HERE! :) |
A great help, if not a 100% solution.
I've been very concerned to make my GY-HD 201E(b) firewire connection as foolproof as possible. An added urgency is that I have a lengthy hand-held shoot this week and while firewired to a wandering lap top computer..... A recipe for an inadvertent unplugging disaster if I ever saw one.
It seems to me that there are two basic problems: 1. Not to forget to power down before plugging or unplugging the firewire. 2. The danger of a plug being pulled out carelessly or inadvertently. I think this solution for a 200 series covers both dangers and seems to work well. What you need: 1. A dedicated 6pin-6pin firewire cable 2. a narrow roll of black stretch rubber auto-adhesive tape, (the kind used on pipe work that binds permanently with itself, NOT black plastic insulating tape). 3. A 1 1/2 foot length of Velcro The 'Hooked' faced half should be the strong auto adhesive type, the soft looped faced part should not be adhesive. 4 1 pr of sharp scissors On the 200 series: Just to the front of the HDV/DV switch and above the composite plugs there is a space on top of the camera that runs over the top, narrowing in front of the heat fins. Shape a piece of the self adhesive hooked Velcro to fit this space and stick it snugly into that space. Immediately under the firewire socket there's the slidable shoulder pad. If you carefully slide your fingers between the pad and the camera chassis, you'll find a dip in the pad with a flat plastic bottom, hidden inside the pad, just above where your shoulder makes contact with it. Cut another strip of hooked self adhesive Velcro and stick it facing hooks upwards to the plastic base of the inside of the shoulder pad. This is fiddly, but you are already winning! The Cable: Cut some 4 inch strips of the rubber insulating tape, peal off the protecting layer. Wind a first loop very tightly (stretch it) around the firewire cable just so that it sticks to itself leaving a long piece hanging lose. Loop a length of soft Velcro tightly over the rubber tape and around the Firewire cable leaving two long crossed ribbon ends protruding beyond the plug, (it will look like the yellow welcome home ribbon). Bind the Velcro looped over the cable tightly with the lose end of the rubber tape. Again stretch this tight and onto itself so that the Velcro is frimley trapped under the tape just before the firewire plug, but with the two Velcro ends protruding above and below the V shape plug. you will now find that you can attach these Velcro ends tightly to the the camera top and inside shoulder pad Velcro, and the plug really wont fall or pull out. To make it easier you can extend the Velcro attached to the camera and the pad with soft Velcro strips and overlap with a hook faced strip to catch the plug Velcro. Use the same technique on the other end of the Firewire cable - I've stuck self adhesive hooked Velcro to my dedicated laptop above and below the firewire socket, now that end won't inadvertently come out either. While the cable now sprouts lengths of Velcro, that goes a long way to avoid the power off problem because if that Velcro doesn't remind you to switch things off first, nothing will! If it's not neatly done it may look a little like the aftermath of a road accident, but it works and could save you a $2000 repair bill |
Troubleshooting HD100u FireWire port issue
Stuart – very nicely done!
JVC – listen up, it’s time for you to step up to the plate and take a foam hammer to some engineers’ head. I just recently purchased (eBay) a HD100U and suddenly realized the seriousness of this FireWire port issue. So, I have been following all of the advice so far (haven’t been able to build Stuart’s contraption but may engineer my own). I had a strange issue after shooting my first test footage and attempting to capture it using a Dell 630 with a 4 pin FireWire plug. Naturally, I needed to use a 6 pin to 4 pin FireWire cable to make the connection (using Sony Vegas Pro and/or Adobe Premiere Pro). It was very disappointing to watch the video capture (HDV-HD30P) start successfully then promptly started `seizing.’ I started troubleshooting everything I could think of and everything I could find online staying up into the wee hours of morning. The only thing that saved my camera from total destruction was its sexy shape and my wallet. I decided to purchase a PCMCIA FireWire card with 6 pin ports and a new FireWire cable. I then placed both laptop and camera (on A/C power supply) on a table and connected the new FireWire components (cam powered down). Being extremely careful not to move any connection I started a capture using Vegas (expecting the worse) and pleasantly watched while it captured all of my test footage (differing frame rates - HD/SD) without issue. I also then tried out Adobe OnLocation with great success and a whooping holler from me loud enough for the dog to howl along. So, I have no clue if I’ve just repeated someone else’s post but if I have kindly excuse me, I’m a tourist here (so far). I hope someone finds this information useful…oh, and by the way, this camera rocks for what it is and I look forward to shooting some great shorts with it and different lens. Matt |
howling over a cooked firewire port - again
This one is the third and counting.
The appropriate precautions have been taken in-house. Problem is that the camera goes out on client capture jobs after a shoot or hires. I am trying to trouble-shoot for the owner. The camera in this instance is a HD-101. It has had the DR-100 firmware upgrade. Last night, the DR-100 did not want to shake hands with the camera or could not. To be assured we had not mismanaged the DR-100, or that it had itself caught some affliction, I brought the camera home here to see if the firewire port was working. The computer in HDV and DV modes does not see the camera in either Premiere Pro 2 or AspectHD, so it would seem it is fried wire time again. Before I consign the owner to chucking himself down on the ground in a headbanging rage kicking up dust or jumping in the Swan with concrete boots on, I would hope that somebody could confirm the camcorder menu settings for successful HDV capture. The JVC user manual to me is a bit if a handful and there seems to be no clear instructions on capturing via the firewire port beyond establishing that wires go here and there and that it works. Existing Settings :- External HDV/DV switch to HDV. HDV PB OUTPUT 720P PB TAPE AUTO 1394 REC TRIG. SYNCHRO BACK SPACE [HDV] P-TAPE DR-HD100 A. OFF "ON" This camera is DRUM HOUR 000141H and FAN HOUR 000356H old, which makes this whole firewire issue all the more depressing, not the least being that by the time the ditch tax (cost of flying parts across the Pacific and applying some profit) is levied, plus workshop charges, the cost of fixing one of these things is about $1000-00. Nobody offers to sell you the part for a fixit yourself solution. The owner has two cameras. neither now worth a damn. He is thinking of sucking it up, forgetting about the DR-100, excellent solution it has otherwise been and shelling out for a ProHD deck and computer for in-house captures for clients except there has been some past bad press about the JVC decks too. The DR-100 has been such an excellent tool for moving footage to client's computers, it is a shame that obscene umbilical cord is the crippling weak link in the whole workflow. If anyone has any advice to offer regarding camera settings which might be hiding a perfectly functional firewire port, any advice will be appreciated. Sadly it looks like wrist slashing time for the owner but while there is a chance of life in the firewire port, there is a parallel hope for the owner's wellbeing. Final note. The captures to my computer from the JVC has been flakey, as in one good capture, then the next with pixellations, then the next good or maybe pixellated, a random thing. There is no such problem with the Sonys. Sometimes, AspectHD reports "camera driver in a bad state" which requires the camera to be shut down and restarted, apparently one of those "learn to live with it and love it" things. Any help or advice appreciated. |
Overdue preventative fix Mk II
I now have a "field tested" and proven update to my last post and need to add one or two stills to illustrate my proposed preventative fix.
In the meantime JVC appear to care quite a lot about customer relations, I would think that they would be keen to make what is after all a known and disastrous design danger point, fixable at a very reasonable cost. They can't need much persuading surely as it would certainly win them a lot of loyal friends in these difficult times. |
I own a HD 110u and this whole fire wire issue is ridiculous! And has anyone had issues with a split screen thing. One side is a magenta while the other is a greenish... Issues with the CCD imager. Jas anyone had these same issues? I treat this camera like gold and there seems to be nothing but issues with it. My next buy will be a HPX HVX or Red.
A PREVENTATIVE FIREWIRE FIX - Mk 2
I've now had the chance to fully test and improve my earlier suggested “preventative fix” against this fried firewire circuit problem. I doubt that it’s completely foolproof but it could help save a lot of money. I hope it helps:
Camera Engineers know this firewire problem well; it's not confined to JVC though these cameras do seem particularly vulnerable. One Engineering Company I respect set about producing a standard fix but finally told me that there are just too many different cameras and pieces of equipment fitted with firewire to make a universal solution viable. I spent some time experimenting on my JVC GY-HD 201E(b) camera-Firewire-laptop set-up. If you have another camera you may be able to adapt it to your own needs, it's certainly worth a thought as damage is so common and repair costs are so high. So, "Here’s one I baked earlier...” TAKE 2: It seems that there are three basic problems: 1. It’s oddly easy to forget to “power-off” before plugging or unplugging the firewire connection. 2. The danger of a plug being pulled out carelessly or inadvertently is very high. 3. The danger of attempting to plug in a firewire upside-down is also very high. All three are seriously dangerous especially if you hire out or lend the camera. Forget my earlier idea of self-stick Velcro on the camera chassis, in prolonged studio conditions it gets hot enough for the Velcro slide. However, I found that Velcro on the computer/ recorder end of the cable worked well. This NEW IMPROVED solution for GY-HD 200 series cameras addresses the three dangers. As earlier, a priority was to keep alterations to the camera chassis itself to an absolute minimum or none at all. What I needed: 1. A dedicated 6pin-6pin firewire cable 2. A narrow roll of black stretch rubber self-adhesive tape, (the kind used on pipe work that binds permanently with itself, NOT black plastic insulating tape). 3. A 9 inch length of Velcro The 'Hooked' faced half should be the strong self adhesive type, the soft looped faced part should not be adhesive, (keep this Velcro for the recorder end of the cable) 4. 1 meter of non-stretch nylon cord 5. 1 small stainless steel “O ring” – like a very small key ring 6. 1 small, strong stainless steel spring clip 7. A short length of heat- shrink transparent wiring plastic tube (a diameter that before shrinking will slip over a firewire plug). 7. 1 pr of sharp scissors 8. 1 soldering iron On the JVC HD-GY 200 / 250 series: THE NEW CAMERA ANCHOR POINT. Note, you can fix the “O ring” and “clip” the other way around as I did (see shot), but the following might be best: Double the length of nylon cord, slip the middle fold through the “O ring” (or clip) and then the cord ends back through the cord loop. The “O ring” (or clip) is now trapped in the centre of the cord. Add a simple knot at each side and just before the trapped ring (or clip) and it wont slide. Feed the cord over the top and under the GY-HD 200 series camera just behind the Firewire socket so that the “O ring” (or clip) is positioned exactly to the left side of the Firewire socket, the cord runs up and over the top of the camera (towards the front of the cooling fins) and down the left hand side of the camera (there is a neat channel there where the power/ component box is attached to the back of the camera chassis. Feed the other end of the cord down under the camera behind and above the sliding shoulder pad and up the left side of the camera. Note the “O ring” (or clip) is now carefully positioned parallel to and just to the left side of the Firewire socket. This is where you want it to be anchored. Note: While the nylon cord won’t stretch, it will slip around the camera, so you now cure that: With the “O ring” (or clip) in the correct position look at the top of the camera and note the exact points ON THE CORD where it curves over the top and down right and left sides of the camera. Lightly mark THE CORD at those camera edge points. Remove the cord and tightly bind the marked spots with short lengths of stretched rubber tape. It will bond to itself and create two non-slip right-angled corners where the cord will run over the top of the camera and down the chassis sides. Loop the cord back onto the camera (as it was) and you should find the “O ring” (or clip) positioned where it was, just to the side of the Firewire socket, and that when pulled tight, the cord will no longer slip. You’ll now need to chose the best spot for the main cord knot (either at the bottom of the camera just behind the shoulder pad, or as I’ve done, at the bottom right side of the camera (below the firewire socket). Being sure to keep the “O ring” (or clip) positioned correctly, tighten the cord and securely tie the knot. Before this main nylon knot slips VERY CAREFULLY cut and tidy the cord ends and seal the knot off (slightly melt in the cord ends) with the heated soldering iron. Needless to say, don’t risk touching the camera or yourself with the iron, both would hurt! Your camera now has a strong anchor point (the “O ring” or clip); it’s now firmly fixed just to the centre left of the firewire socket. THE DEDICATED FIREWIRE CABLE: Note the top edge of the ^ shaped firewire plug and using a white indelible felt tipped pen, identify the top edge of the plastic bit of the firewire plug. Once dried cover the white mark with heat-shrink transparent wiring plastic tube and, making sure that the metal part of the plug is not covered, heat-shrink the tube. Now you will remember to check when plugging and always know the right way up! Now fix the spring clip (or “O ring”) to the firewire cable far enough behind the firewire plug to cause a "swan neck" bend in the cable when it’s plugged to the camera and clipped to the new camera anchor point. Here's a picture - more follow. http://server6.theimagehosting.com/image.php?img=Camera end adapted firewire cable.jpg Note that the top of the Firewire plug is marked by a white identifying stripe and you can see that if you pull on the cable, the strain will be taken by the clip and camera anchor point - not the fragile firewire connection. As you'll see I've done this with the clip on the camera cord and ring on the cable - it makes little difference. I started by reinforcing and stiffening the camera end of the Firewire cable (to give it powerful spring) with more of the stretched rubber tape. Then, using a 3” length of cord I strapped the spring clip (or “O ring”) cord with a short length of the rubber self-bonding tape so that it was hanging behind, and to the left side of the firewire plug itself. This end of the cable is now finished. Plug it into the camera and clip it to the “O ring”, it will produce the swan neck bend in the firewire cable which will hold the plug in tightly and is unlikely to accidentally pull out. The clip and “O ring” have transferred the “pull” to the cord around the camera. Use the same technique on the other end of the Firewire cable - I've stuck self adhesive hooked Velcro to my dedicated DV Rack laptop (above and below the firewire socket), now that end won't inadvertently come out either. While the firewire cable now sprouts lengths of Velcro, it goes a long way to avoiding messing up the “power off first problem” and if this contraption doesn't remind you to switch things off first, nothing will! Those of you with other cameras may be able to adapt this same principle, I grant you that if it's not done neatly it may look a little like the aftermath of a road accident, but I now use this modification and assure you that it works. It sounds complicated but was easy enough to do and could save you a very expensive camera repair |
| All times are GMT -6. The time now is 11:16 AM. |
