SD 60p to SD 24p at DVinfo.net
Old May 9th, 2006, 02:01 PM   #1
SD 60p to SD 24p
I'll after the famous slow-motion trick with the HD100 but i seem to be stuck.
I imported the footage into my compy using AVCVideoCAp
then opened in StreamClip. What do i do to change the frame rate in the original clip?
Export at a quicktime with a different time base?
Adam Craig
Los Angeles, CA
www.showiki.com - Entertainment Biz Wiki
www.filmexposure.org - My Media Company
Adam Craig is offline   Reply With Quote
Old May 9th, 2006, 02:20 PM   #2
Well, i got it to work... A bit of a pain in the a$$ but still.
1- Shoot the footage in SD60P
2- Capture to a m2t file on the compy using AVCVideoCapture
3- Open the m2t file in StreamClip (export at quicktime)
4- Open in CinemaTools and "Conform" to the speed you want.. I choose 24fps
5- Open in FCP and you're ready to edit your 40% SlowMo footage.
Jeez, i hope apple/JVC make this process abit easier.
Adam Craig
Los Angeles, CA
Old May 9th, 2006, 02:43 PM   #3
ops, my bad
Adam Craig
Los Angeles, CA
Old May 9th, 2006, 07:20 PM   #4
Did you get good results? (I like how you answered your own question by the way. -Classic)
I'd be interested to see what it looks like. On other 60p footage I've seen from the camera, there's a flicker every 6th frame. Could this be the 6 frame GOP perhaps??? uh-oh... It's not always apparent unless you boost the levels quite a bit. Tim Dashwood posted a 60p clip of a guy walking around a corner and pigeons flying through the air. It was neat, but under-exposed. So I lightened it up and noticed the strobing effect. I can't remember if it got lighter or darker every 6th frame, but it was there. Could be a neat effect, but not always... Anyone else see this?
Chad Terpstra is offline   Reply With Quote
Old May 9th, 2006, 07:31 PM   #5
is AVCVideoCAp software? If so, where can I obtain it?
Steve Benner is offline   Reply With Quote
Old May 10th, 2006, 02:10 AM   #6
Here you go:
http://developer.apple.com/sdk/#FireWireX
I haven't noticed any strobing yet but i will take a look. My skinkin' compressor proggie refuses to work properly. I need to reinstall and compress the video for the web.
Adam Craig
Los Angeles, CA
Old May 10th, 2006, 04:19 AM   #7
Here you go:
Which download is it, the first one?
Old May 10th, 2006, 09:16 AM   #8
Yeah, then you'll find the program under /developer/FirewireSDK22/Applications/
After you install it.
http://media.filmexposure.org/60p24p.mov
-aj
Adam Craig
Los Angeles, CA
