-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   JVC upgrade update: (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/68567-jvc-upgrade-update.html)
Carl Martin June 12th, 2006 03:52 PM
Originally Posted by Enzo Giobbé
I was under the impression that the first QR-JVC 7/14 either worked or didn't.
Our first batch of QR-JVC 7/14 units did not work at all (you had to jiggle the battery - not a good workaround :). These were in the under 0000100 serial number range. They were replaced with QR-JVC 7/14 units in the 0000275 to 0000325 range, and all of these worked (and show the time remaining correctly).
What is the serial number range of the unit you have Carl? It might be a good idea for us in this forum to post a serial number range of QR-JVC 7/14 units that work, and those that need to be sent back to AB for an upgrade. Such a list would have saved you a lot of time and fiddling around.
I don't believe this menu exists any longer on any production HD100 with the AB QR-JVC 7/14. The menu combination you listed was accessible on the pre-production HD100s with the pre-production QR-JVC 7/14 unit attached (at least ours were).
See my post here: http://www.dvinfo.net/conf/showpost....&postcount=132 for more info.
CS at AB is superb, and I have had many discussions with Sol and Mike over there. Nice people, and very knowledgeable, but they can only give out the information supplied to them.
The correct key sequence to get into the Anton battery voltage setting on upgraded "A" cams is STOP+MENU for about 5 seconds (just hold it down until the menu appears, or hold down that combo and power the camera on).
You cannot set the dead camera voltage lower that 12V (you could on the pre-production units accessed by the the old menu key). Be aware that unlike most pro video cameras, the "alarm" setting on the HD100 affects the dead cam kick-in. If you set this any higher than 12.1 or 12.2V, you will start to get the blink of death while you still have usable battery power left, and the cam will pretty much sign-off (cam is still on, but will not record).
Set at 12V alarm, the real time display is pretty much in sync with the RT display in the HD100 VF. Set at 12.5V, you will get a tally blink when there is at least 15 minutes or more of usable non-reserve power left in the battery, and if you are using a Ultralight 2, the VF will start to black out momentarily when the Dionic battery reaches the 1/4 power remaining mark. The HyTRON 50 will start to act that way when it goes below the half way point.
JVC needs to make the dead cam voltage adjustable to under the 12V minimum setting they have now (most cams are adjustable down to 11.2 - 11.5V) on a future firmware upgrade.
Enzo,
This is all good info to have. Maybe once all of the serial numbers are listed, they could make this a sticky thread. serial number: 8375-0061
Enzo Giobbé June 13th, 2006 03:07 PM
Originally Posted by Carl Martin
Enzo,
Carl, I think that's a stock number. Unless AB has changed the serial number series, all of ours are numbered "00000XXX" (not sure about the exact numbers of zeros at the beginning of the number, but there are a ton of them). Should be located on the left side of the adapter (white label).
BTW, when you get the unit back, you will love the RT display!
Carl Martin June 13th, 2006 07:25 PM
I have no label of any kind on the bracket. I was luck to find the baggie it came in, and this is the number written on the AB label. QR JVC 7/14 HDV 8375-0061.
Carl Martin June 14th, 2006 09:07 AM
Enzo,
I just spoke with AB, and they tell me that the earlier QR JVC 7/14 HDV brackets were not serialized. So if anyone has these brackets, they must get the upgrade in order to see time and capacity in the VF. This is also a free upgrade.
Carl
Warren Shultz June 14th, 2006 10:55 AM
Has it ever become clear what the voltage readout should actually be in the viewfinder?
I had an upgraded unserialized mount that read 7.2V before the camera had the "A" upgrade. After the upgrade a fully charged Dionic 90 now says 16.4V.
I have a second mount (Serial # 000000000232) that also gives the 16.4V reading. At one time I thought I understood it should be converting to the 7 volt range.
Carl Martin June 15th, 2006 01:35 PM
Here is what ken has wriiten to me as far as the update is concerned.
"I do wish there was an easier way but there just isn't on the first run of the original brackets. I do know however that of the estimated brackets out there that need the mod we have already updated 80% of them so there are not many left...
Let me know if there is anything else you need and you can just keep the serial # blank on the form".
Carl Martin June 22nd, 2006 11:36 AM
Well, I just got off the phone with Ken over at AB, and he says that my old non serial numbered bracket does in-fact show time and capacity on their HD100. I told him that I don't understand, you were the one that told me it needed to be updated. He then said that he is sending me a brand new bracket and that I should try that one. He also suggested that the (A) update to my camera may have failed, I then said that everything else seems to be working fine.
My question is. Is it possible for everything to be working fine, except for the time and capacity reading in the VF? I am able to see voltage. I also can see the other sellections under battery options. Is it also possible that my update was installed half-ass? I sure hope not. I cannot afford to send it to CA again.
Carl Martin June 23rd, 2006 01:19 PM
I just got my bracket, and it works like a charm. The VF now reads voltage, time, and capacity. Thanks to Ken Cyr over at AB for a great job!
