Powering the DR-HD100
I just bought a DR-HD100 for $995 off of EBAY. It was a "B-Stock" mint condition HDD that was used to demo at NAB 2006 and then was repackaged by JVC. I thought it was a good deal...I should have it by Friday.
Anyway...I have the Anton Bauer Battery Setup...What cable do I need to have the battery power the Firestore drive? |
Steve,
I'm very interested in this as well. When I bought the camera attachment package from Focus Enhancements I thought it would include a cable of some kind but it didn't. I currently power mine only with the on board battery. Please let me know if you find anything else that works. Thanks, Tom www.tomchaney.com |
Hi Webb,
Will that cable work with an IDX system? Thanks, Tom Chaney |
Thanks Webb
[QUOTE=Webb Pickersgill]You need this cable:
http://www.bhphotovideo.com/bnh/cont....x=0&image.y=0 Webb how exactly does that work? Please be more specific. I have DR-HD100 and Anton Bauer batteries. How can I power both the camera and the DTE recorder with the same battery? Is this PowerTap cable the solution?How is it connected? I'd appreciate your help. Thank you. |
Jaadgy, the cable runs from the DR-HD100 to to little connector on top of the A/B mount. There is a small 2-pin slot/connector called a power-tap on all A/B mounts that can be used to power anything needing 12v. This same Powertape can be used to power on-camera lighting, or an on-camera external HD monitor. Very handy.
Tom, I've never used IDX so I don't know what kind of connector it has. If IDX uses the same shape/style plug as A/B then it would be compatable. Can someone who uses IDX confirm? |
Here is a picture of an accessory power cord plugged into the IDX mount:
http://www.dvinfo.net/gallery/showimage.php?i=238&c=16 Here is a post (the second one in the thread) that says an AB power tap cable works on an IDX mount: http://www.dvinfo.net/conf/showthrea...t=66692&page=2 |
Jack and Webb,
Thanks, I will place the order tonight. Tom |
| All times are GMT -6. The time now is 08:24 PM. |
