Varizoom VZ-PRO-L at DVinfo.net
Old October 26th, 2006, 02:16 AM   #1
Varizoom VZ-PRO-L
would this Varizoom VZ-PRO-L work on the JVC101e
john
John Doran is offline   Reply With Quote
Old October 26th, 2006, 06:02 AM   #2
john
The one I use for my camera is the VZ-PG-F its an 8 pin that fits the stock lense.
Gary Williams is offline   Reply With Quote
Old October 26th, 2006, 07:32 AM   #3
LANC is a consumer standard not suited to professional applications. The ENG-style lens on the HD100 uses an 8-pin connection common to most professional broadcast lenses.
Stephan Ahonen is offline   Reply With Quote
Old October 26th, 2006, 07:37 AM   #4
Lanc
thanks guys
a guy has this one for sale would it work:
"Fujinon SRD-92B zoom control"
john
Old October 26th, 2006, 07:42 AM   #5
I've got the JVC HZ-ZS12U (Fuji SRD-91) and it works very well.
Tim Dashwood
Old October 26th, 2006, 07:45 AM   #6
zoom
thanks
i would really need to know if this one would work, are you using it with the jvc101
john
Old October 26th, 2006, 07:49 AM   #7
thanks
john
The HD101 is a Pro camera so it doesn't have LANC. If you want to control a Fujinon lens, you need a zoom controller compatible with 8-pin fuji port on the lens. The VZ-PRO-L is a LANC controller for consumer cameras.
Since Fuji 8-pin is a standard that has been around forever, it should be easy for you to find a zoom controller, especially in the used market.
Tim Dashwood
Old October 26th, 2006, 07:51 AM   #8
zoom
tim
thanks , i am not clued up on this, but this Fuji SRD-91 seems to have a 8 pin and all i want to know if it would work, its a secondhand item and i acnnot return if it doesnt work
john
Old October 26th, 2006, 07:53 AM   #9
tim
john
If you look closely at my post above, that is the exact same one I own. The JVC part number is HZ-ZS13U. It works well.
Tim Dashwood
Old October 26th, 2006, 07:59 AM   #10
zoom
tim
thanks,
yours is :JVC HZ-ZS12U (Fuji SRD-91)
Mine: Fujinon SRD-92B zoom control
the difference is SRD-91 and SRD-92B
it has :one central pin with seven arranged equally around it. do you think it will be ok
john
Old October 26th, 2006, 08:10 AM   #11
I have a great Varizoom package that would work for sale, see the classified section:
http://www.dvinfo.net/conf/showthrea...462#post563462
www.digitalfx.tv
Greg Milneck is offline   Reply With Quote
Old October 26th, 2006, 08:12 AM   #12
As long as there are 8 pins and not 12 it will work fine. The difference between the 91 and 92B is that the 91 only has zoom and REC, but the 92B has REC, Zoom and an auto variable speed controller.
Tim Dashwood
Old October 26th, 2006, 08:13 AM   #13
zoom
thats a 12 pin
thanks anyway
john
Old October 26th, 2006, 08:22 AM   #14
tim
tim
thank you very much
all the best
john
Old October 26th, 2006, 05:21 PM   #15
I am going to buy one of these. Is there a reason the 92B would be preferred over the 91? or vice-versa?
I have the JVC focus controller on the other handle and want the zoom. I am using this for shooting stage shows.
Jack Walker is offline   Reply
