User Buttons at DVinfo.net
Old October 31st, 2006, 05:50 PM   #1
User Buttons
Is it possible to input the Scene File Recipes on different user buttons ( user 1, user 2, user 3)? Or do I have to buy a "memory" card, if so, where is the best place in Los Angeles?
Tommy
Tommy Davis is offline   Reply With Quote
Old October 31st, 2006, 07:52 PM   #2
Nope. That's not what those buttons are for.
It's not a "memory" card, it's just a memory card without the quotes. It's included with the camera when you buy it new, but in case you buy it used and the card isn't included for some reason, then you can get a replacement just about anywhere. It's a standard, plain jane, average, ordinary, ubiquitous, run of the mill, very common, readily available Secure Digital (SD) flash memory card. Best place in Los Angeles is the nearest Walgreens. It'll set you back about fifteen bucks. Get the smallest capacity you can find, like a 32 Megabyte or 64 Megabyte if they even make them that small anymore.
x
Old October 31st, 2006, 08:16 PM   #3
Got it, thanks Chris!
Old November 8th, 2006, 07:46 AM   #4
Most people have AE shift (+ and -) on those buttons, I'm willing to bet. There aren't that many possibilities to set them to, but you should consider that there's no other way to change the AE setting unless using the menu (but that's defeating the purpose of AUTOexposure somewhat...).
High-Definition Video Consultant - CEO of Delimex NV - http://www.delimex.be
gear of choice : http://www.wespgear.com
Werner Wesp is offline   Reply
