Foam Inserts at DVinfo.net
Old December 4th, 2006, 04:50 PM   #1
Foam Inserts
Curious as to where I can purchase a foam insert to fit the JVC HD100. Anyone anyone?
Matt Setnes is offline   Reply With Quote
Old December 5th, 2006, 05:15 AM   #2
Is this what you mean?
http://stores.benl.ebay.be/kofferfun...QQftidZ2QQtZkm
High-Definition Video Consultant - CEO of Delimex NV - http://www.delimex.be
gear of choice : http://www.wespgear.com
Werner Wesp is offline   Reply With Quote
Old December 5th, 2006, 03:34 PM   #3
thanks wesp! Only problem is the obvious, its not in English.
Old December 5th, 2006, 05:59 PM   #4
Ah, what do you need translated? :-)
I'm no native german speaker either, but as a belgian guy, I have to be able to make conversation in 4 languages, eh?
Problem is: I have been looking for this myself for a very, very long time, and I absolutely couldn't find anyone retailing it. Eventually I ended up at a manufacturer that makes furniture, they had it but couldn't sell to a private person (but eventually we could make a deal) and I can tell you it wasn't cheap in anyway. After I got it there I found this seller (so my point is that I really doubt there are a lot others out there). I suppose they will send it everywhere in the world and if you don't understand their german, they'll surely be happy to help you in English if you send 'em a mail (we europeans all speak serveral languages :-) ).
(http://www.kofferfunshop.de/contact_us.php or just an email at: info@kofferfunshop.de)
Old December 5th, 2006, 06:03 PM   #5
Isn't that page in Dutch? That should be OK for a Belgian guy to translate, right?
Maat Vansloot is offline   Reply With Quote
Old December 5th, 2006, 06:07 PM   #6
good news my friend:
go to http://www.kofferfunshop.de and on the right side of the screen you can select english. That way you'll have the whole site in english...
Old December 5th, 2006, 06:09 PM   #7
Nupe, that's in german. I should know because dutch would be my native language indeed... (on that count: german and dutch are a lot alike, so I can understand the confusion)
(the .be in the link is because I watched that via the belgian ebay....)
Old December 5th, 2006, 07:11 PM   #8
thanks for the help. Problem is I bought a JVC case off ebay hoping to use it for the JVC HD100. My guess is it's the CB 2990 fitted for the DV550U. If I did my math right I would need 2 foam inserts in dimensions roughly around 762 x 533 x 178.
I called JVC and I asked what would happen if someone damaged their inserts, and the answer I get is they would have to buy another case. With that sort of answer I'm not very pleased with JVC right now. Maybe carl can provide some insight.
Old December 6th, 2006, 08:06 PM   #9
I purchased foam from a fabric store when I made my case. Cost me 40.00 to get a sheet of foam 36wx96lx7d
I just cut it to fit.
Jim Fields is offline   Reply With Quote
Old December 6th, 2006, 09:16 PM   #10
Hey Jim, you mind telling me where you got it from?
Old December 6th, 2006, 11:10 PM   #11
I just went to a fabric store in Plano TX. They had alarge selection in the back, from thin, to thick.
I would not try Joanne Fabrics as they might not, but do try some smaller ones.
Old December 7th, 2006, 02:12 PM   #12
What is this certian type of foam called? or is it just "foam" ( :
and what did you use to cut the foam?
Old December 7th, 2006, 03:45 PM   #13
Furniture upholstery shops are another good source for foam. They usually have a big selection of various types and thickness. Most of time, a large sharp knife (like a kitchen knife) is all you need for cutting the foam. Some folks have recommended electric carving knives, and there are also hot wire cutters for making complex cuts in foam.
Another option is a company that specializes in foam packaging for electronic equipment cases. It's usually very expensive for a one-off, but you do end up with a totally custom fit.
Ralph Keyser is offline   Reply With Quote
Old December 7th, 2006, 03:51 PM   #14
Images: 10
there's a trick to cutting foam. if you can find a freezer large enough, freeze it befor you cut it. beleive me, it gets so easy when it's hard ;o)
Old December 7th, 2006, 04:16 PM   #15
Thanks for the tips guys. So far I've only found white foam...which I guess is okay but not for $40 and good for one side. I'm having doubts any upholstery shops will have it in grey. I actually have a freezer big enough, i will definitely try that out.
