Can I shoot 60p with the HD110? at DVinfo.net
Old January 9th, 2007, 12:01 PM   #1
I bought an HD110 with the impression that I could shoot 60p with the unit, but the frame rate settings appear to be exactly the same as the 100. I've got HDV-HD30p and HDV-SD60p as my options. I thought I would see HDV-HD60p on the choice list but it's not there. Am I missing it or is it not possible? Thanks for any help.
Pete
Pete Lewis is offline   Reply With Quote
Old January 9th, 2007, 12:13 PM   #2
Not an option for the 100 or the 110 I have one of each. You need to move up to the 200 series to get HDV60p. Sorry.
Jerry Porter is offline   Reply With Quote
Old January 9th, 2007, 12:17 PM   #3
You can use the SD-HDV50/60 Modes and then Upress to 720. It is a good workaround for Undercranked motion. If you want 720/60P you need the 200 or 250 as stated above.
Steve Benner is offline   Reply With Quote
Old January 9th, 2007, 12:22 PM   #4
That's what I was afraid of, but thanks for the help.
Old January 9th, 2007, 12:52 PM   #5
The camera does send a 720/60P signal out of the component outs. It can be captured using a Kona Card setup.
Old January 9th, 2007, 02:06 PM   #6
Is it 60P???? I thought it was uncompressed 30p. Either way I know it's 4:2:2 uncompressed out of the analog outs. Make sure you have taken care of capturing sound also if you go this route.
Old January 9th, 2007, 02:23 PM   #7
720P60 on analog out when in 720P30 mode, and "720P48" (in a special pulldown pattern within 720P60) when in 720P24 mode.
Tim Dashwood
Old January 9th, 2007, 02:50 PM   #8
Cool you learn something new every day.
