DV to HDV Conversion Question at DVinfo.net
Old March 12th, 2007, 12:41 PM   #1
Hello,
I have a tape that is a dub of BetaSP footage onto a miniDV tape. The tape plays on my camera with an image when the camera is set in the DV 60i mode. It does not play an image in the HDV mode.
I need to use the images on this tape as B-roll for a video I am already editing on a 24fps HDV timeline in Final Cut. Using Tim's work flow (found at www.dvinfo.net/conf/showthread.php?t=83228) which uses DVHSCap then MPEG Streamclip - then Cinema Tools...how do I get my DV footage to work in a HDV timeline with, I guess, a different frame rate?
This question shows my ignorance of understanding what all of these applications do and how the timeline and capturing and frame rates and everything all work. As I get answers to all the questions I post, I hope I will figure this all out and understand the applications on a more fundamental level so that I feel more comfortable playing around with them and finding out answers to road-blocks on my own. Problem is, I rarely know where to start to look and I get frustrated and want to give up.
Sharon
Sharon Pieczenik is offline   Reply With Quote
Old March 12th, 2007, 12:54 PM   #2
what are you editing with FCP ?
in FCP you should capture the DV material as DV. then drag the DV clips into your HDV TL... done, as long as your HDV is 30(29.97) and your DV is also NTSC, there's nothing to do. FCP will scale to fit when you do the drag and drop. if your DV is 4:3, then you'll have to decide if you want to side letterbox, or blow it up. if its 16:9, its already the right side. there are some 3rd party filters that might handle the blow up better like digital anarchy resizer. I'd HIGHLY suggest you RTFM the FCP manual because most of this video basics is in there.
Steve Oakley is offline   Reply With Quote
Old March 12th, 2007, 01:23 PM   #3
But what if my timeline is 24fps? That is what I need the B-roll to go on? Is it possible?
I am using final cut.
Old March 12th, 2007, 01:24 PM   #4
Steve,
May I politely suggest you read the original post carefully before ranting at people who are simply asking for help. If you did, you'd have noticed that Sharon is working with a 24fps HDV timeline. Thus, everything you have written in response is not only rude but also inaccurate. Your grammar could do with a little help as well.
Sharon,
I'm not entirely sure but, I think you'll need to use cinema tools to change the frame rate to 24fps, once you've captured it as DV, of course. Then you can drop it into your HDV timeline and resize.
Hope that helps,
Liam.
Writer-Director-DOP
www.liamhall.net
Old March 12th, 2007, 01:31 PM   #5
Thanks Liam. Will try.
Cheers,
Sharon
ps- say hi to London for me...would love to live there one day
