-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   setting up the jvc hd201 with redrock m2 (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/89573-setting-up-jvc-hd201-redrock-m2.html)
Tony Webber March 22nd, 2007 07:47 AM
i read on here that some people have got this setup to produce good images.
Does anyone have any tips on how to get it setup; how to get the height of m2 and camera correct, which shims to use etc
also when i tried to set it up the other day, with the weight of the m2 and lens, the rods started bending, has anyone else experienced this?
focusing is also a pain, i havent managed to get sharp images yet.
any suggestions welcome
Drew Curran March 22nd, 2007 09:42 AM
Tony
Have you tried the alternative imaging section of this site? (your post may be moved there by the mods)
You should also try the M2 forum at the redrock site. I'm sure there will be loads of advice there.
Andrew
Tony Webber March 22nd, 2007 09:47 AM
i had a quick look through both forums, most of the info seems to be about using the m2 with the hvx200
Tim Dashwood March 22nd, 2007 11:08 AM
Taylor Wigton is the resident ProHD/M2 expert around here. He spent alot of time figuring out how to properly align the rig, and has shot some amazing stuff with it.
S. Abdul Jamal March 22nd, 2007 11:09 AM
it's in the jvc section but you need to be registered.
Djee Smit March 23rd, 2007 04:30 AM
I believe he recently posted an article from showreel magazine in which, i believe, he also talked about setting up the jvc with the m2. I can't find it that quick, but try to look for that.
*edit* I found it:
http://www.dvinfo.net/conf/showthrea...135#post638135
Tony Webber March 27th, 2007 04:52 PM
cheers for the replies, i didnt realise i needed to register for private forums, got lots of info now though.
