IIDX battery and DR-HD100 bracket at DVinfo.net
Old May 5th, 2007, 03:52 AM   #1
Hi,
I'm using 2 IDX Endura 7s batteries with my HD-251.
The Endura's don't last that long with the HD251, DR-HD100, and PAG light.
The DR-HD100 is mounted on the back with the new bracket. I'm wondering if a IDX Endura 10 with a 7s will fit between the DR-HD100 bracket and the camera.
My other option is to buy 1 or 2 Endura 7 batteries. So I can slide the 7s battery on the back of a Endura 7.
Anybody else using 2 Endura's athe the same time with a DR-HD100?
Marc Jayson is offline   Reply With Quote
Old May 7th, 2007, 06:08 AM   #2
i think the difference is about 3cm, how much room do you have to spare?
a question: how do you power the dr-hd100 from the idx batteries? I´m have the idx mount plate for the hd110 and am thinking about switching to tapeless as well, but I´m not sure how to power the hd.
Thomas Weilguny is offline   Reply With Quote
Old May 7th, 2007, 08:24 PM   #3
There is a "D" power tap on the IDX mount. This allows you to run what ever you want from the IDX battery. Monitor, light, HD, etc. as long as you can find a D tap cable for your item.
I believe that the JVC bracket for the JVC HD (IDX Kit) comes with the proper cable.
I purchase a battery from Batteries4Broadcast and that battery comes with a D tap right on the battery. In theory I could run the HD and a small on camera monitor at the same time using both D taps.
Dan Weber
Daniel Weber is offline   Reply With Quote
Old May 8th, 2007, 01:39 AM   #4
I'm using the D Tap on the IDX mount with splitter for the PAG light and the DR-HD100. I only connect the DR-HD100 when the battery is getting low.
I'm going to measure the space I have left later today.
Old May 9th, 2007, 06:01 AM   #5
I just tried to fit 2 Endura 7s batteries and that doesn't fit. The gap between the IDX mount and DR-HD100 bracket is about 6cm.
Old May 9th, 2007, 10:24 AM   #6
I also have 2 stackable IDX E7 batts. Also very interested in using the d-tap power since I highly covet a firestore drive. Also like to power my lectro receiver and litepanel, so I'm looking at a splitter. I'd never run 3, since the lectro can easily go to 9 volts.
The E7s is not stackable. at first I hoped that the cheaper batt could "feed" the power link, but it receives from a different place. I guess I could hang a Batteries4Broadcast with a d-tap on back, and just dedicate that to accessory power. This should work, right?
With the JVC/IDX mount priced at $300+, I'm very motivated to find alternate rigging for wireless and firestore. BEC has a bunch of useful modular mounts, and I'm not above bending aluminum or strapping a bag on either....
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old May 9th, 2007, 01:55 PM   #7
I just got an email from my dealer, he told me I can adjust the bracket so I can fit a E7 and E7s! I'm going to check this as soon I'm back home.
