How to label a SDHC card at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
GY-HM150, HM100, HM70 recording AVCHD MP4 & QuickTime .MOV to SDHC cards.
Old June 5th, 2009, 10:29 AM   #1
I am wondering how to go about labeling a SDHC card. I thought I could keep the cards for different projects separated but that isn't going so well. There is no space to write on the cards. I don't know what pens I can use to write on the cards. Can you write on the hard plastic part or do you have to find a spot on the label. I was just thinking about writing a letter on the back on one. I don't know what do you guys think?
Calvin Bellows
www.exposureproductions.ca
Calvin Bellows is offline   Reply With Quote
Old June 5th, 2009, 10:37 AM   #2
I've written numbers on the back (non-label) side of SD cards using a fine-point _silver_ sharpie (much more visible than black when writing on a blue card).
There are various SD card wallets / storage cases out there for multiple cards... you could number each card and then keep an index on a piece of paper or large label in the storage case.
But a more important question: Has anyone done a serious study of the shelf life of data stored on SD/SDHC cards? (As compared to archiving on hard drives, DVD-R, etc.)
Bob Richardson is offline   Reply With Quote
Old June 5th, 2009, 01:00 PM   #3
I might start using sharpie dots/dashes and maybe three letter codes or probably just dates for simple organizational labeling -- will work especially well on the whitish Delkin 16GB Class 6 cards I just got. The push-button topped sharpie will be handy for quick field labeling.
- different numbers of dots ... 060509 *, 060509 **, etc.?
- different colors? (red dash will mean card full??)
- then promptly put the cards for each project in a card-organizing page in a binder or at first in a sturdy/protective card wallet stored safely in zipped pants/shorts pocket?
- back up to Firewire bus-powered miniRAID in the field after downloading to laptop
Shaun Walker is offline   Reply With Quote
Old June 8th, 2009, 02:04 PM   #4
labels generally aren't recommended, but the thin plastic labels printed with my brother labelmaker fit very neatly into the indent of the card, and I feel good about them.
Just make sure they are trimmed to fit, and keep an eye out for lifted edges.
fine point sharpie makes sense though...
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
