Jvc-gy-hd110 focus changes help me thanks ! at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old November 6th, 2009, 12:36 AM   #1
i have JVC-HD110 camera WHY MY focus changes when i move the camera i mean when i zoom and focus and then i move the camera to something different .
the focus go out of focus any help thanks .
Tamim Amini is offline   Reply With Quote
Old November 6th, 2009, 09:58 AM   #2
a pro type lens needs to be re-focused when moving from 1 subject to another that is nearer or farther away than the original subject that was focused on. obviously there is no auto focus (that's worth using) on a pro lense. however it COULD be the backfocus is out
Don
Old November 6th, 2009, 10:10 AM   #3
You must set your backfocus to get
the correct flangeback, on the other side
some user switch on the makrofunction of
the lens.
The result due to the focus is the same like
a wrong flangeback.
Eric Deyerler is offline   Reply With Quote
Old November 6th, 2009, 03:02 PM   #4
my back focus is ok i know when my back focus is out so it is not the back foucs ?
Old November 7th, 2009, 12:49 AM   #5
what do you mean by switch on the makrofunction ?
Old November 8th, 2009, 03:02 AM   #6
When you use for minimum object-distances
the macro on your lens (on Fujinon you must
switch a little plastic switch - on Canon-lenses you
push and change in the macroarea of the lens),
sometimes that will be forgotten when its
only 1 mm on the macro.
Then it looks like a incorrect flangeback (backfocus).
Old November 17th, 2009, 01:22 AM   #7
Contributor
Tamim - don't know if this is a communication problem but you do realise the camera doesn't autofocus? When you move the camera on to a different object at a different focal length from the lens of course you have to re-focus... that's expected.
If you are referring to zoom in and focus and zoom out,the object you originally focussed on should remain in focus IF the backfocus is set correctly. The only exception would be if you had your iris stopped down too far (anything much above F5 for 1/3" chips, F8 OK at a pinch) - nothing will ever focus correctly then. It may "appear" to be in focus when zoomed in but it is not -it just becomes more apparent on wider shots.
John Mitchell is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
