JVC GY-hmc 710u vs Panasonic AG-hmc150 - Page 2 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old October 31st, 2012, 05:38 PM   #16
Re: JVC GY-hmc 710u vs Panasonic AG-hmc150
Does the 710 come with a Anton/bauer mount stock or do you need to buy one? Is it the same as the GY-HD 100? I still have my 100 so I guess I can use the lense and other things as needed. One more thing, Are all the 700 series cameras the same in low light? 710 vs 750?
Randy Johnson is offline   Reply With Quote
Old October 31st, 2012, 09:11 PM   #17
Comes with the AB mount standard. the lens is interchangable with the HD series. As for low light, my understanding is that the 750 was better than the the 700 and the 710 is the same as the 750.
Minimum Illumination for the HM750 = 1.25 lux (1920 x 1080 mode, f/1.4, +18dB, w/8-frame accumulation)
Minimum Illumination for the 710 = 1.25 lux (typical) (1920 x 1080 mode, f/1.4, +18 dB, with 8-frame accumulation)
These specs from B&H spec sheet on each camera.
Don
Old November 1st, 2012, 09:59 AM   #18
Thanks Don. I have a HMC 150 plus a old GY-HD 100 as long as the low light and pictures are better than my 100 im happy.
Old November 1st, 2012, 10:11 AM   #19
The HM700 is definitely better in low light than the HD100 I use to used both together at one time until I sold the 100 to get another 700. I guess that a 710 or 750 would be a bit better than my 700.
If you are use to the HD100 then the HM7** will be a revelation not only is it better in low light but also the viewfinder and LCD screen are much much better; larger, brighter and sharper.
As regards batteries. Here in UK they were sold with a V-Lock plate, thought there was a AB option. It's exactly the same fitting as on the HD100 and it's very easy to change the plate. I took the AB plate off my old Panasonic DV200s and use the Trimpacs until they gave up the ghost. I now use V-Lock.
George Kilroy is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
