Sony tape rewinding problem at DVinfo.net
The Long Black Line
Old October 25th, 2007, 02:35 AM   #1
In the past month, I have encountered an issue with all three of my Sony cameras. If the tapes are recorded beyond the 30-40 minute point, the cameras cannot rewind them. The C32:23 error occurs when attempting to rewind the tape, and the tape must be ejected. When this happens with the FX1, the eject mechanism moves slowly and sometimes gets stuck altogether, remedied by gently pressing down on the tape carraige. In all cases, there is visible crinkling on the outside edge of the tape after ejecting.
I have found a way to rewind without encountering the problem, by 'seeking' rather than 'fast' rewinding (IE, holding down the rewind button during playback). There are no problems in playback or recording.
I have only been using brand-new, sealed Sony premium tapes. I am wondering if it is possible that a large block of Sony tapes are either defective or had a design change. It is as if the 'fast' rewind causes a jam of some sort. It is remarkable that all three of my cameras have this same problem with recent Sony tapes purchased in the past few weeks.
I've read a few forums describing the remedy to the problem is to 'whack' the camera on the side. No way am I doing that! Especially since all of the cams are doing the same thing, the problem points to the tapes.
Wondered if anyone else has ecountered this.
Dan Robinson is offline   Reply With Quote
Old October 25th, 2007, 07:02 AM   #2
Call me crazy, but have you taken maybe a different brand tape, one that is recorded from a 'non crucial' project and see if it stops then. If it doesn't, I think you'd be on track to say you may have a bad batch of tapes, or maybe take the ones that are jaming now and try to rewind them in a different camera. I dunno, tape issues scare me to death.
Steven Davis is offline   Reply
