Help with DV tape transfer to Beta sp at DVinfo.net
The Long Black Line
Old March 12th, 2008, 07:21 PM   #1
I need the help of an expirenced Beta person!!!
I have a mini dv sony GVD1000 that i want to transfer tape from to a sony uvw1800 beta sp recorder.
i have the s video hooked up out to the uvw and i have the rca to xlr hooked up to the audio channels
the uvw still reads no signal
any help would be Greatly appreciated!
Kirk Graham is offline   Reply With Quote
Old March 13th, 2008, 10:10 AM   #2
Check the input switch on the front of the UVW-1800 and make sure it's correctly set. Should be set to S-Video, also menu setting should have the machine in "EE" and you may have to press the record button to actually see video pass through. Don't forget to also set the audio input switches on the back of the deck to the 600 setting.
Rick L. Allen is offline   Reply With Quote
Old April 30th, 2008, 11:00 PM   #3
I have done this numerous times with no issues. I also hook up the video out and I take it into the Ref Video In. It syncs the video so the picture does not roll during recording.
Greg Laves is offline   Reply With Quote
Old May 1st, 2008, 05:17 AM   #4
Thanks for the replys
i got it figured out the machine needs a reference video so that fixed it asap!
