Longer Duration Tapes? at DVinfo.net
The Long Black Line
Old May 12th, 2008, 12:07 PM   #1
I need a miniDV tape that is longer than 85 minutes. Anyone out there know a good place or do they even exist?
www.facebook.com/projectspecto
Marco Wagner is offline   Reply With Quote
Old May 12th, 2008, 12:11 PM   #2
Contributor
They don't exist, as far as I know.
Old May 12th, 2008, 12:21 PM   #3
They don't exist in the miniDV formfactor. You can store lots more time on a standard DV cassette but that would require a different recorder.
Depending on your applicaiton you might be able to rent a Firestore or nNovia type DVR to get the longer record times you need. You could export the footage back out to tape from your edit system for an archive.
http://www.LandYachtMedia.com
Old May 12th, 2008, 12:50 PM   #4
Thanks y'all. I just need to get 1:31:09 onto a miniDV tape from Premiere timeline...looks like dual layer DVD will be the solution.
Old May 13th, 2008, 11:18 AM   #5
You could output LP if MiniDV is the only option. I did that for a two hour film to play at a film festival since they didn't accept DVDs. It worked out very well.
Edward Phillips is offline   Reply With Quote
Old May 16th, 2008, 06:48 AM   #6
Used an 80 minute tape on LP last night. 2 hour runtime total. Seemed to work... :)
Nate Haustein is offline   Reply With Quote
Old May 16th, 2008, 05:08 PM   #7
Thanks all
yup, I did that wednesday night and it worked like a charm!!!
