Playback of tapes recorded in LP on different cam? at DVinfo.net
The Long Black Line
Old July 5th, 2009, 06:10 PM   #1
At times I find I'm forced to use LP rather than change tapes. Current recording is via Pana DV852.
i) Can any mini-dv camera play back (allow capture) of those tapes? The camera manual notes that "tape recorded at LP may not be played back on other cameras".
ii) If the tapes recorded in LP are captured much later - (months, years), is there likely to be a problem? It seems there is less margin for error.
Obviously changing tape is best, but it is not always an option. But between
i) 80 min tape at SP- only PQ and SQ are available in this lenght not AMQ
ii) 63 min tape at LP
which is the least bad option?
Laurence Spiegel is offline   Reply With Quote
Old July 5th, 2009, 07:19 PM   #2
Contributor
The least bad option is to use an 80 minute tape, in my opinion.
Old July 5th, 2009, 09:00 PM   #3
Hi Laurence,
"i) Can any mini-dv camera play back (allow capture) of those tapes? The camera manual notes that "tape recorded at LP may not be played back on other cameras".
ii) If the tapes recorded in LP are captured much later - (months, years), is there likely to be a problem? It seems there is less margin for error."
If you're lucky, you may be able to capture from another Cam, or from the same Cam you did the original recording on. But, don't bet on it. Between the spec differences between Cams and the Heads waring over time, it get's more unlikely over time. If you do use the slower speed, then do your capture ASAP.
Like Bill says, using the longer tapes is the best option, if you can't record to some other medium - like a computer.
I use the 80 min tapes when time is an issue, and have had good luck with them. Some folks have reported not having such luck with the longer tapes. ?????
Harold
Harold Schreiber is offline   Reply
