Digitizing 8mm tapes in to DV Codec at DVinfo.net
The Long Black Line
Old August 20th, 2012, 04:16 PM   #1
Hi everyone-
I am ingesting about 30 120-minute 8mm tapes through a Black Magic card, and while I would usually just ingest em as a Pro Res or an uncompressed file, the files are just way too big. I simply would not have enough space for all of them. There wouldn't be any loss of quality to ingest them at NTSC-DV codec would there? The ones I have done so far look pretty good.
Matt Weckel is offline   Reply With Quote
Old August 20th, 2012, 05:49 PM   #2
Re: Digitizing 8mm tapes in to DV Codec
I assume you are backing these up and using AVI or MOV. ut So I am not sure what Analog to digital loss could occur.
If you plan of using them for an edit later on you can uprez in a number of programs bue t when I copied some Hi8 over I used Premiere Pro and used a scene change to break them down into smaller files.
I have a mumber of segments from some salt water fishing shot in the early 90's that I injested and then uprez and cleaned up for recent series. Other than some over saturation and a line or two on start and stops they worked adn looked fine.
Bringing and entire 8MM tape in on one file is looking for problems
Dan Herrmann is offline   Reply With Quote
Old August 20th, 2012, 06:45 PM   #3
Totally fine...
The weak link in the chain of transfer is usually in the deck itself...
Otherwise, there is no problems using this codec. I stores more than enough information the source provides.
Old August 20th, 2012, 07:34 PM   #4
Best choice is a Digital8 camcorder or deck that converts the 8mm Video8 or Hi8 to DV. Not all the Digital 8 camcorders did this but most did so. I use my old TRV 740.
Ron Evans
Ron Evans is offline   Reply
