Best brand of miniDV tapes? at DVinfo.net
The Long Black Line
Old October 21st, 2006, 02:37 PM   #1
I'm new to all of this, so please bear with me.
I have just received my first miniDV camera Wednesday, and now I need tapes.
I have a couple of questions now.
1). What brand do you use, and what would you say is the best?
2). Is there any other tapes that are a "wet lubricant" other then Panasonic?
3). Is there really a difference in the quality on some tapes, compared to others?
~Gabriel~
Gabriel Photography
Gabriel Yeager is offline   Reply With Quote
Old October 22nd, 2006, 12:32 AM   #2
A lot of these issues get re-hashed over and over, and nobody really knows anything. I would just keep a lot of tape stock on hand (because you're in trouble if you run out) and get whatever's cheap (miniDVs are <$3 online). Other factors are way more important than what tape you use (and we don't really know if brand X is significantly better).
Factors like:
checking your tapes after you shoot them
not screwing up (i.e. label your tapes)
letting the camera temperature equalize
having good content
etc.
2- Panasonic uses dry lubricant I believe... Jan Crittenden used to say otherwise, but was misinformed.
3- Picture quality is the same. miniDV records 1s and 0s on the tape. Error correction ensures that those 1s and 0s are read back correctly.
Old October 22nd, 2006, 10:11 AM   #3
Thanks, Glenn. Sounds great. Thanks for correcting what I said about the Dry/wet lubricant. I think I'll use the Panasonic's that I have on hand.
is it sony that is the only wet lubricant? I believe that is what I just read.
~Gabriel~
Gabriel Photography
Old October 22nd, 2006, 07:57 PM   #4
They are all fine.
Just use each tape twice. Once to record, once to playback. Then store it. New shoot = new tape.
Jimmy McKenzie is offline   Reply With Quote
Old October 23rd, 2006, 10:42 AM   #5
Originally Posted by Jimmy McKenzie
They are all fine.
Thanks, Jimmy! I like the way you worded that. :D I think its time that I go out and start shooting now.
Thanks everyone!
~Gabriel~
Gabriel Photography
