Using Manfrotto monopods - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
Old November 18th, 2006, 06:43 PM   #16
I picked up the 694 version recently - used it while on vacation. It worked great.
Stephen Sobel is offline   Reply With Quote
Old January 16th, 2007, 05:37 PM   #17
Manfrotto 560B Base - friction connected?
I recently received a Manfrotto 560B and I noticed that the fluid cartridge slides off. I think it's defective. For anyone that has one, does the fluid cartridge just rotate but not come off the monopod?
Mike Yoneda is offline   Reply With Quote
Old May 6th, 2007, 06:06 AM   #18
Location: Oxford, UK (until 2008: Lhasa, Tibetan Autonomous Region)
Manfrotto 560B Questions
Two last questions before I order one:
- is there a way to attach a pan to the "head" that comes with the 650B?
- the 66cm/26inch is still a little to long for the bag I usually take on a plane. Is there a way to dissemble the 560B in order to shorten it for transport?
thanks!
Martin
Martin Saxer is offline   Reply With Quote
Old May 9th, 2007, 10:53 PM   #19
Two versions of the Manfrotto 560B?
Manfrotto has apparently changed the design of the base legs. In the link bellow there are two PDF files. The one with serial numbers from A0516988 and up shows the original design. The new design starts with serial number A0762962 and up. Does anyone know if B&H have the updated design?
http://www.manfrotto.com/Jahia/spare...otto/pid/13877
Adam Palomer is offline   Reply With Quote
Old May 9th, 2007, 11:05 PM   #20
Attaching Pan Head
Martin,
I have a bogen 503 attached to my 560B. All you need is a 1/4" to 3/8 inch adapter. Unscrew the 560 B head and attach the adapter. Most tripod heads will mount to the 3/8 screw.
JonathanSchwartz
Owner,CA Video Productions
Jonathan Schwartz is offline   Reply With Quote
Old May 12th, 2007, 03:15 AM   #21
I just realized that I missed a word in my question:
is it possible to attach a pan HANDLE to the "head" that comes with the 560?
Martin
Old June 2nd, 2007, 10:10 PM   #22
Pan handle
Martin,
No you can not attach a pan handle to the head (without some welding). But the head easily come off to expose a 1/4 inch bolt or you acan get an adapter to an 3/8 inch bolt. The more we use this monopod the more we like it. For the price, I do not think you will be dissappointed.
Jon Schwartz
Old June 8th, 2007, 02:04 AM   #23
I take it that NONE of you have purchased one from B&H?
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Monopods (incl. FlowPod)
