CameraBright Light at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
A compact 720p MPEG4 digital media camera recording to SD Card.
Old December 26th, 2006, 10:10 AM   #1
CameraBright Light
Has anyone tried this light - designed specifically for the HD1/HD1A
http://www.camerabright.com/x1-er-plus-Xacti.htm
Richard Shirley is offline
Old December 26th, 2006, 03:40 PM   #2
I bought the regular model, which didn't seem bright or wide enough to be really useful. The only difference in the Sanyo model, as far as I can see, is that it has a little tilt top attached so that you can angle it up from the tripod socket.
I don't like lights under the camera (Frankenstein effect), so I attached mine to the top with velcro which seemed to solve the angle problem, but as noted, it didn't help much.
Peter Solmssen is offline
Old December 27th, 2006, 09:20 AM   #3
Thanks for the comments. Good point about mounting the light on top.
Anyone have any other suggestions for a good lighting solution for the HD1/HD1A?
Old December 27th, 2006, 09:59 AM   #4
Most of my indoor shooting is done in my livingroom, so I purchased a couple of pole lamps that aim at the ceiling. This ambient lighting for great pictures, plus the ability to capture video without the common grainy appearance and autofocus hunt that happens with low light.
Whatever solution you choose, I suggest you try for ambient light instead of a direct flash. Even a bounce flash will offer improvements. Your pictures will look more natural and your subjects won't cringe when you pull out the camera. ;)
Chris Wells is offline
Old December 28th, 2006, 05:02 AM   #5
Press Release
http://www.marketwire.com/mw/release...ease_id=196976
Robert Batta
my stock video portfolio :
https://www.pond5.com/artist/skysuta
Pond5 – the world’s first web-based stock footage marketplace –
Robert Batta is offline
Old January 2nd, 2007, 01:30 PM   #6
Out of curioisty, is the light stable enough to use as a "tripod" or a mini-stand when you want to set the Sanyo down for a second or two, and also compensate for the angled lens? That might be a neat little added benefit.
Justin Liu is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > (MPG4) Sanyo Xacti (all models)
