Pro Titler 2 Color Picker at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > NewBlueFX plug-ins
NewBlueFX plug-ins
Stabilzer, blends, effects and more for Mac & PC editors.
Old March 13th, 2013, 12:22 PM   #1
I find the Color Picker in Pro 2 awkward with its HEX values. Is there any way the version from Pro 1 can be used? Or have I simply got my settings wrong?
David Dalton is offline   Reply With Quote
Old March 14th, 2013, 01:40 PM   #2
Sponsor: JET DV
Re: Pro Titler 2 Color Picker
I have checked and it was changed mainly so we could make good multi-point gradients and see the results in real-time. Is the biggest sticking point that you simply want to have a standard RGB entry? If yes, I'm sure that could probably be added or it could be made switchable between Hex and RGB. I've forwarded this request on to the proper people.
Old March 15th, 2013, 02:59 AM   #3
Hello Edward
Yes, standard RGB is what I find easier to work with. The picker in the original version was a doddle to use.
Thanks.
David
  You are here: DV Info Net > Cross-Platform Post Production Solutions > NewBlueFX plug-ins
