Audio problems capturing from Z1 at DVinfo.net
Old September 10th, 2008, 06:38 AM   #1
It's been hard to find anyone who may have had a problem like mine, because most people capture to a specific editing program, but let's go.
Even if I usually do my editing with Avid Xpress, sometimes I use a simpler capture program called WinDV. I use it to capture from my Sony Z1 and PDX10 video cameras, and through my Canopus converter.
Lately I'm having a problem when capturing from my Z1 that I can't figure out. When I down-convert an HDV tape I get files with no sound. The sound is there, because I listen to it as I play the tapes, but the captured files are mute.
Today I tested the files again, capturing from Avid, and the audio was fine. So where is the problem?
I thought it might related to WinXP and the SP3 update, but I installed another WinXP with SP2 on another HD, and I am getting the same.
The camera setup is fine, or there wouldn't be a capture from Avid, and if I play DV tapes on the Z1 I also get audio alright.
I am getting out of options on what else to try.
Any suggestions?
Carlos E. Martinez is offline   Reply With Quote
Old September 10th, 2008, 07:43 AM   #2
Carlos, this is a shot in the dark, cause I don't know WinDV, but could it be an option in the program? Perhaps by mistake you've turned off audio capture and left it just video?
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old September 10th, 2008, 07:47 AM   #3
No, it's not. Same problem happens with Windows Movie Maker. Does not happen when playing DV in either program. Does not happen when capturing from Avid.
Old September 10th, 2008, 09:42 AM   #4
Allright. Does WindDV have an option to let you choose your audio hardware device? Perhaps that's not set right.
Old September 10th, 2008, 09:47 AM   #5
It does not, neither has Movie Maker.
Old September 10th, 2008, 12:30 PM   #6
I'm out of ideas...
Old September 11th, 2008, 07:57 AM   #7
I have used WinDV for years, it's a wonderfull small program.
Try capturing DV footage - do you get the same error?
Second, take a look at the properties of the footage captured with Avid and compare it to the properties of footage captured with WinDV. There must be a difference somewhere.
Ervin Farkas
www.AtlantaLegalVideo.com
Old September 15th, 2008, 07:16 PM   #8
Can you detail how you're importing using canopus? The most direct and effective way to capture is through a firewire cable connected from your camera to your computer. in addition, you can specify it to down convert in the camera's menu.
Pete Cofrancesco is offline   Reply
