About USB/FireWire/PCI Cards at DVinfo.net
Old March 4th, 2004, 01:29 PM   #1
Do you specifically need one of these cards or *another* card(s) to get the footage captured? I know DV uses FireWire, and my motherboard came with FireWire, USB, the Sound Card, and ethernet card/ports inside of them, do I need to get another one? What's the difference between the motherboards that carry these and buying a seperate USB/FireWire card? Is it better to get them independently?
"Everyone has a photographic memory. Some just don't have film."
David Ho is offline   Reply With Quote
Old March 4th, 2004, 01:53 PM   #2
No!, If your motherboard already have a firewire port on it, you are a lucky guy, use it and save the cash of the firewire card for other things!
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old March 4th, 2004, 02:01 PM   #3
David, Mother board or PCI slot mounted cards should not be a consideration. As far as firewire or USB goes, ite depends on what interface your camera supports. My xl1s supports firewire.
I also have a still digital camera that supports USB.
Joe
Joe Pitz is offline   Reply With Quote
Old March 4th, 2004, 03:02 PM   #4
I believe my GL2 supports the USB and FireWire, but I am saying would I need to buy another card. Now, what you just said is to not use the motherboard FireWire ports?
Old March 4th, 2004, 04:30 PM   #5
David,
You should be fine using both the firewire/usb port from your motherboard.
If you need extra firewire/usb ports you can add then. But you should be fine with what you have.
Joe
