What type of pc/software do you recommend? at DVinfo.net
Old June 28th, 2004, 02:05 PM   #1
I am looking to build a new PC for DV editing. I am getting into the event videography business. I can't decide whether to just use my existing amd 3000+, 2gb ram, 9800 pro and add a matrox rtx100 card and some more storage space or to build a new computer.
Will the above config work well for dv editing? If not what would you recommend?
I am going to be filming using a pd170.
I was thinking of using the adobe software that comes with the matrox rtx100 card.
Paul Maxe is offline   Reply With Quote
Old June 28th, 2004, 02:12 PM   #2
Capt. Quirk
You didn't mention how much storage you have, but I would say your system is more than adequate.
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old June 28th, 2004, 02:49 PM   #3
I will be buying 500gb of external HDD space. Is there a huge difference between my AMD machine and a new dual processor setup?
Also...Does the Matrox RT100 package offer 100% RT editing? Waiting for renders is a pain...
Old June 28th, 2004, 03:29 PM   #4
Re: What type of pc/software do you recommend?
<<<-- Originally posted by Paul Maxe : I am looking to build a new PC for DV editing. I am getting into the event videography business. I can't decide whether to just use my existing amd 3000+, 2gb ram, 9800 pro and add a matrox rtx100 card and some more storage space or to build a new computer.
I was thinking of using the adobe software that comes with the matrox rtx100 card. -->>>
Do I need the Matrox card?
Old June 29th, 2004, 02:32 AM   #5
Hi Paul,
Your computer setup should be fine for running Premiere and an RTX100.
You do not really need an RTX100 as most of the stuff in PP is real-time. However what you do get if you go for an RTX100 is:
Real-time MPEG 2IBP import and export
BITC (Burned in time code)
analogue in and out
lots of real time effects...
Check this document out:
http://www.matrox.com/video/products...re_summary.pdf
Check this page for the RTX 100 system requirements:
http://www.matrox.com/video/support/...o/rec/home.cfm
I would suggest to try and get a demo with the RTX 100 and download the tryout for PP from adobes website.
cheers,
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline   Reply With Quote
Old June 29th, 2004, 01:41 PM   #6
What Ed said.
You have a great system for it. You could spend more, but the gain would not knock your socks off. As mentioned, throw in HD space. 1 hour of tape is about 13GB. Edit, render, and make a DVD and you have double it. I had one project run to about 100GB and I was seriously and aggressively economizing on space. It could have used 200GB easily. It you are working on more than one at a time, it racks up.
George Ellis is offline   Reply With Quote
Old June 29th, 2004, 02:32 PM   #7
Is Premiere Pro as robust as Final Cut Pro?
Old June 30th, 2004, 02:57 AM   #8
Paul,
Thats very subjective...
For a start they both run on different platforms.
Some say running on a Mac is faster and less prone to crashes, where as others will disagree. They both have pros and cons.
Its a bit like comparing apple and pears...
Please do not turn this thread into a platform war.
Cheers,
Ed Smith
Hampshire, UK
