Help with AE export using Avid DV compressor at DVinfo.net
Old April 19th, 2006, 07:01 AM   #1
I've been trying to render out a clip from After Effects 6.0 using the Avid DV compressor but I only seem to get a gray frame with rivets.
Here's a link to a frame of the render:
http://www.filamtelevision.com/images/dvCodecTest.mov
I've tried using all combinations of rendering RGB,million colors, premultiplied.
The clip is exported from Avid 3.5 using the Avid DV compressor -- and that works fine, I can successfully import that clip into AE but --
Any ideas why I can't render out a clip from AE 6.0 using the same Avid DV compressor ?
As an aside ... I'm am using the upgraded codec package from Avid -- I keep getting a "cannot export bin error" when I try to export from Avid using the "same as source" + "use Avid codec". With the upgraded codec package, the Avid DV compressor shows up on the custom codec pull down menu.
I'm trying to avoid recompressing in a different codec when I re-import that clip back into Avid which then has to re-compress yet again, I believe.
Thanks !
Jay Sanchez is offline   Reply
