exporting 16:9 so that it is letterboxed on VHS at DVinfo.net
Old May 6th, 2003, 05:19 PM   #1
Hello, I taped somthing on my GL2 in the "in camera 16:9" format, but I am having problems exporting it back on to my GL2 so that it is letterboxed instead of the streatched 4:3. I am using premiere 6.5
the end result I am looking for is to have my footage on a VHS tape so that it is letterboxed 16:9
what is the best way to do this?
thanks!
Jonny Throop is offline   Reply With Quote
Old May 6th, 2003, 06:50 PM   #2
Have you checked the Help file? This was a problem in prior versions because of the PAR bug but was fixed in 6.5 and should work fine if you follow the procedure.
David Hurdon
David Hurdon is offline   Reply With Quote
Old May 6th, 2003, 07:44 PM   #3
There should be a preset for the clip that keeps the aspect raito 16:9. RClick the clip and goto video then keep aspect ratio I think. Just off the top of my head.
Rob:D
Robert Poulton is offline   Reply With Quote
Old May 7th, 2003, 06:01 AM   #4
RED Code Chef
Create a 4:3 (!!) project in premiere and import your 16:9 footage.
Now drag the footage in the timeline, right-click on it and select
Maintain Aspect Ratio. This will auto letterbox it. You can now
send it back to the camera in your usual way.
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
