settings? at DVinfo.net
Old June 16th, 2007, 06:11 AM   #1
settings?
I have some footages shot on an XL2 in 16:9 mode (PAL).
Does it matter if I unsqueeze the footages or not during digitising?
Secondly, what should be the correct export settings for XL2 16:9 footages? 1024x576 or 960x576?
Zulkifli Yusof is offline   Reply With Quote
Old June 16th, 2007, 02:35 PM   #2
The digitizing has already been done in your camcoder. When you capture to your computer, basically you transfer a file; you don't have options.
The PAL standard works with 720x576 pixels regardless of the aspect ratio. If the footage is 16x9, then the only difference is that it's "flagged" as such.
Ervin Farkas
www.AtlantaLegalVideo.com
Old June 23rd, 2007, 07:15 AM   #3
Ok, thanks for that.
Secondly, since I shot the project in 25p mode, would it make sense to edit on a 25p timeline or there is no difference between a 25p timeline and 25i/50i timeline?
