NTSC / PAL issue at DVinfo.net
Open DV Discussion
Old October 12th, 2007, 11:49 AM   #1
NTSC / PAL issue
I have shoot coming up and a client requested that we shoot in PAL format. No problem as I own a Sony Z1! So i set it in 50i mode and shoot. However, we do want to use a secondary camera for additional broll (its a canon xlh1) and i know that doesn't shoot PAL unless you pay canon to convert it (which i dont want to do). The client doens't need us to edit the shoot, so, i'm wondering, is there anyway we can get the Canon's footage converted to pal that is relatively inexpensive and easy to do? Any thoughts/feedback appreciated!
Spike Spiegel is offline   Reply With Quote
Old October 12th, 2007, 01:51 PM   #2
You might want to check out Atlantis from DVFilm.
It has been recommended several times earlier.
Not sure if it works with HD, but it is reportedly giving good results with SD.
http://www.dvfilm.com/atlantis/
Old October 12th, 2007, 05:40 PM   #3
Try and Rent another Z1 it will match better
Old October 13th, 2007, 12:21 PM   #4
atlantsi does the good job, but the result is bit different from original footage, i guess it exports only progressive files
Andzei Matsukevits is offline   Reply With Quote
Old October 15th, 2007, 01:46 PM   #5
Procoder does a decent job (for the price) transcoding NTSC to PAL DV-AVI or vice versa.
Ervin Farkas
www.AtlantaLegalVideo.com
Ervin Farkas is offline   Reply
