Right Angled XLR? at DVinfo.net
Open DV Discussion
Old December 28th, 2007, 02:05 PM   #1
Right Angled XLR?
Where can i find a shorty right angled XLR, i tried searching BH and couldnt find one (under 18ft). I just need one to hookup my mic to the Canon XH A1...
Id prefer a place where I could also order the ExpoDisc White Balance from as well, to save a little in shipping
Alessandro Garabaghi is offline   Reply With Quote
Old December 28th, 2007, 02:35 PM   #2
It didn't show up in a search for me, either; apparently they're just labeled 'angled' connectors: http://www.bhphotovideo.com/c/produc...le_to_XLR.html I knew I'd bought one there before, it was just a matter of digging through the menus to find it.
Seems they have plenty of choices when it comes to ExpoDisc diameters, too, if you plug the name into the search box.
Robert Martens is offline   Reply With Quote
Old December 28th, 2007, 02:36 PM   #3
yea im just gonna get the 72mm for the Canon...
Old December 31st, 2007, 03:50 PM   #4
You may want to specify which Right Angle direction the cable is set to as they can go in different directions in relation to the pins. Do you want it to point down, to the left or the right? You will probably be able to rotate the mic in the mount so the connector points the correct way but some mics do have a direction to be pointed properly or switches which you want access to relatively easily.
Old December 31st, 2007, 03:53 PM   #5
Images: 10
http://store.a2zcable.com/connectors-audio-xlr.html
Old January 2nd, 2008, 11:19 AM   #6
on B&H's site do a search for "XLR Cable" then on the left hand side of the results there is a filter for the length of the cable. Pick "Up to 10ft." Right now there seems to be 68 cables under that filter. On the first two pages of the 68 results I count about 5, five foot and shorter cables with a right angled connector on one end. Several of them seem to be "Hosa" and the 1st one seems to be "Audio Technica."
HTH...
Kevin
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply
