Why Panasonic.....
Here in India every one in the field uses Panasonic cams MiniDV (broad casting) rather than Canon though it's more versatile (what I feel), can any one tell the advantage of Panasonic over Canon.
I have XL2, which is giving me good results, & greatest advantage is using of EF tele lens for bird photography. I don't think this advantage of using 35mm lens on Panasonic cams is not possible. Ashok |
Video cameras can be a personal decision as well as an issue of familiarity. Some will stick with Panasonic because it has been producing broadcast gear longer than Canon. Others have legacy equipment that will only work with one brand. Its the same issue with Nikon vs. Canon in still photography. They are always close in performance and features.
Unless you point out a specific camera, it is hard to make a blanket statement about which one is better. As a brand, they are both well regarded. |
Still not convinced........
Thanks, but still I'm not satisfied with the statement; there must be some things Canon lacks in those areas Panasonic perfected.
Hi again, Ashok...........
Knowing India as I do, I'd say Panasonic went to great lengths to sell into that market, which Canon did not.
You mention "Mini DV", which is not, to the best of my knowledge, "Broadcast" equipment in the West. Even Canon does not produce "Broadcast" quality equipment here in the West (or anywhere else, for that matter). I think what you are seeing is simply one manufacturer making greater inroads due to a much larger marketing budget and aggressive priceing. The actual technical abilities of individual cameras is so much less of an issue in the amateur market (I use the term loosely, the camera's you talk of are not "profesional") and thus the bigger the budget, the more they'll sell. There's also "fit and function" to consider. I own a Panasonic Mini DV camera, it's a beut, best in it's class, as were most of the Panasonic dinky cams for the last 3 to 4 years. Bang for buck, there was nothing to beat them. Can it beat a XL2? Get real. But for what you pay, for SD, you get one heck of a lot of camera for not a lot. Don't worry, Ashok, you've still got one heck of a camera system, and it'll beat the heck out of a Panna Dinky Cam, any day. (You MAY want to think about one of the new HD Canons tho', think they're going to be pretty hot). CS |
And Pana has had a full line of SD/HD ENG style cams (big chip) for a long time. Thats not really Canon's market. They have a great rep in the indie/prosumer market, but not broadcast. Sony, JVC, Panasonic are well established in those areas.
Thanks Chris, Dylan,Ken.
| All times are GMT -6. The time now is 10:03 AM. |
