Question on shooting a computer screen at DVinfo.net
Open DV Discussion
Old November 5th, 2008, 01:12 PM   #1
I need to shoot some action that appear on a computer screen. What is the best way to film without getting flickering and clear sharp footage.
I’m shootong with a sony DRC-VX2100
Thanks, Ron
Ron Jones is offline   Reply With Quote
Old November 5th, 2008, 01:19 PM   #2
Location: London, Milton Keynes, Bedford UK & Beijing, China
Hi Ron,
I think it's a question of getting your shutter speed to match the frame rate on the computer - I find 1/60th usually works for me...so experiment.
Sean Walsh
http://www.visionworkstv.co.uk PPro, Z1, EX3 - Currently in Beijing at CCTV-News
Sean Walsh is offline   Reply With Quote
Old November 5th, 2008, 02:02 PM   #3
If you shoot a flat panel, (LCD screen) you won't have the flicker/ black bars that you get when shooting a CRT monitor.
Randy Amos is offline   Reply With Quote
Old November 5th, 2008, 02:10 PM   #4
Or if the graphics card has an S-video out, you can record directly from that.
Edward Carlson is offline   Reply With Quote
Old November 5th, 2008, 03:02 PM   #5
Contributor
I've used this very inexpensive software before on a Mac:
Ambrosia Software, Inc. -- utilities/snapzprox
It allows you to achieve perfect quality with no degradation as you get from shooting a screen. Presumably there is a PC version or something similar.
Old November 5th, 2008, 03:25 PM   #6
Thanks, I’ II try with your suggestions.
Ron
Old November 5th, 2008, 05:57 PM   #7
Try to set the computer's monitor refresh rate to 60Hz, too.
John Miller is offline   Reply With Quote
Old November 5th, 2008, 06:27 PM   #8
Sorry to be a pest, I know there are plenty of suggestions already, and if you have access to the display settings of the computer the 60hz method should be easiest, but you may benefit from the BBC guide on this very subject:
BBC Training & Development > DV Usage Guides - Online course details
Scroll down and click "Open guide 3" next to Shooting Computer Monitors for techniques specific to this particular family of Sony cameras. The one listed for the VX2000 should be the same for the 2100. Takes some fiddling, but I've gotten it to work, and I imagine it could come in handy.
Robert Martens is offline   Reply With Quote
Old November 5th, 2008, 08:54 PM   #9
I've also found that setting the refresh rate on the monitor significantly higher than the cameras framerate works very well. I use 100hz, when available, on a 30fps frame rate. Then you dont have to tweak the camera just right... the monitor does all the work for you. Turn the brightness way down on the monitor and it will show up well without screwing your exposure.
I suppose other refresh rates would work for other fps's. I've never tried with anything but 30fps.
--Andy P
Andy Pronobis is offline   Reply With Quote
Old December 12th, 2008, 01:01 AM   #10
--Andy P
Be careful with that though, if you set the refresh rate too high you could actually do damage to the monitor.
Mark Gentile is offline   Reply
