What is shutter speed and gain? at DVinfo.net
Open DV Discussion
Old December 27th, 2003, 10:50 PM   #1
I am new to camcorders and unfamilar with this vocabulary. What are these two options used for exactly?
David Ho is offline   Reply With Quote
Old December 27th, 2003, 11:08 PM   #2
In photography, shutter speed refers to how long the shutter is left open. If the shutter is 1/60th of a second, then the shutter allows light to hit the light sensing area (the film) for that long. In video it's similar although I don't think there are any moving parts.
Shutter speed affects exposure and the amount of motion blur the camera picks up. High (fast) shutter speeds are useful for certain special FX (since high shutter speeds remove nearly all motion blur).
Gain is electronical amplification of the signals the CCD puts out. It makes the image brighter but also amplifies and adds electrical noise. In low light situations you may need to use the camera's gain.
Old December 28th, 2003, 01:27 AM   #3
Outer Circle
There's 2 types of gain. One was already explained by Glenn, the other one is audio gain.
Old December 28th, 2003, 10:06 AM   #4
Gain is merely simple signal amplification. Unfortunately, noise is also amplified at the same time.
If the quality of mercy is not strained, then how do they get the lumps out?
George Brackett III is offline   Reply
