Best DV codecs? at DVinfo.net
Open DV Discussion
Old February 2nd, 2004, 01:23 PM   #1
Best DV codecs?
This morning I went over the Mainconcepts.de website and saw that they had their own DV codec, which they maintain is the best rated codec out there.
Which DV codecs appear to preserve the best image quality after rendering, and which editing apps support them?
Brandt Wilson is offline   Reply With Quote
Old February 2nd, 2004, 04:08 PM   #2
Hi,
The best DV codec is arguably Canapus DV Codec. Its playback filter is available for free. There have been many tests done that show it degrades under sequential compressions best and its playback filter is also of the highest quality. This codec also maintains the DV format's 16-235 levels.
Best Regards
Johann Adler is offline   Reply With Quote
Old February 2nd, 2004, 04:18 PM   #3
Images: 10
the mainconcept DV codec is one of the best DV codecs available, with the possible exception of the proprietary codecs available from Canopus, Sony Vegas, etc. I beleive it allows a choice of 601 legal or non-clipped color space.
Old February 2nd, 2004, 10:36 PM   #4
Skyonic New York
http://www.emptyloft.com/video5/codec.html
simple test
Robert Mann Z. is offline   Reply With Quote
Old February 3rd, 2004, 10:08 AM   #5
In my own rather extensive testing of codecs recently, the results of which i'll write up and put online at some point soon, the Canopus was the hands down winner.
I actually starting testing other codecs after having such a bad time with the main concept codec. With each succesive generation of a Main Concept file, grossly unappealing mosaic-like blocks began to appear. This was most evident in skies, or walls where gradients might appear, but in some cases on people too!
You can see an approximate effect of this blockiness on the site Robert posted: (Image: http://www.emptyloft.com/video5/dc10004mbits.bmp). And yes, i realize that the image i reference here is not in the main concept codec, this is merely an illustration of the effect that it produces.
Whats worse is that this blockiness was very strong when I simply placed a solid color matte on the timeline and did a fade out or a dissolve on it. (Premiere Pro) Instantly, a heavy mosaic pattern would appear. I'm still baffled at how it could generate that from a single color!
So I moved on and got Matrox's codec and noticed that it handled all of the gradients and solids, and just about every peice of footage I could throw at it when you reduced a couple of generations. I quickly learned however that with each succesive generation, more and more noise was added in the image and by the 4th generation, the footage was largely unwatchable.
On to the Canopus codec (comes with ProCoder). Rejoice. I gave it a tough peice of footage (strong blue gradients, etc), the same i'd given all the others, and it handled it like a pro. No blocks, no noise. I did 10 generations with this one and the footage was still very tolerable, looking better than matrox's 3rd generation and better than main concepts 2nd generation.
Hope this helps
Casey Visco
Glidecam Industries, Inc.
Casey Visco is offline   Reply With Quote
Old February 3rd, 2004, 10:13 AM   #6
Skyonic New York
matrox and avid use softners in ther codec which produce a very nice first gen, but softners tend to hurt future gens...
i saw very little diff with canopus and main concept codec, neither use softners...
the now 6 year old dc card still outshines dv at 25mbits, the 4mbits was thrown in for comparsion purposes...
Old February 3rd, 2004, 10:26 AM   #7
I've noticed with most codecs that first generations are never a problem at all, as was the case with my testing, once you got beyond that is when they start to fall apart.
Casey Visco
Old February 3rd, 2004, 06:11 PM   #8
RED Code Chef
I've seen that test a couple of times before? Isn't that quite
old already?
Rob Lohman, visuar@iname.com
Old February 3rd, 2004, 07:07 PM   #9
Skyonic New York
<<<-- Originally posted by Rob Lohman : I've seen that test a couple of times before? Isn't that quite
old already? -->>>
rob i put that test together about two years ago...so yes it's aged but the codecs have not changed much
Old February 3rd, 2004, 11:50 PM   #10
So is the Canopus codec the concensus?
How well will it hold up to repeated recompression, such as out of the NLE into After Effects, then out of After Effects and back into the NLE, to the VTR? Nearly all of my current project will be subject to 2 or 3 render passes, and I'm concerned about how it will hold up.
Old February 4th, 2004, 12:04 AM   #11
Depending on the length of your clips and the amount of storage space you have, you may elect to use a lossless codec for the intermediate steps, and only in the final phase recompress to DV.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old February 4th, 2004, 12:26 AM   #12
Is this codec free?
Can i use it with an OHCI card?
Ben Gurvich is offline   Reply With Quote
Old February 4th, 2004, 08:00 AM   #13
Skyonic New York
free it is not ....
mainconcept is 50 bucks...
canopus can only be attained by buying one of there hardware cards...procoder software...or edius there new nle...
