Change language on Japanese Sony? at DVinfo.net
Open DV Discussion
Old July 28th, 2009, 01:35 PM   #1
I have a bud I can get a Sony HC90 from, but it's a Japanese version. Does anyone know if I can change the language like on the stateside version of the camera?
Brian Berg is offline   Reply With Quote
Old July 28th, 2009, 03:21 PM   #2
Some cams give you the choice of language if you do a hard reset using the RESET button. Otherwise you'll have to hack the firmware, which might or might not work, might or might not cripple the cam, and will certainly void your warranty. A service center might be able to do this for you but if they are authorized Sony they may refuse to do so.
Sounds like you're getting the cam used so warranty not likely an issue. But if it were me, I'd pass.
Did you mean HC9 or HC90? The 90 is an pretty old cam, and they're only about $350 used at Amazon, and way, way less than that on ebay, where I just saw an English one bidding at about $100 and a Japanese one at about $25. How cheap does it need to be to make it worth the risk?
Old July 28th, 2009, 03:44 PM   #3
It's an HC90. It's pretty old but a pretty reliable camera. I rent them out to hunters so I don't want to spend a ton on them. Who knows? I may run into a Japanese hunter. LOL. I've bought some on ebay for less than $300 all decked out too. Guess I'll do a little more digging .
