Think I burned out my camera.....hmmmm at DVinfo.net
Open DV Discussion
Old May 15th, 2004, 10:51 PM   #1
Well I plugged in my battery charger ps to the camera ...hoping to see if the ps worked cause I think the charger is on the fritz but anyway is there a fuse in my camera that I can replace or did I just really screw up?
This is a Ultura DV cam .
Saw nothing in manual about any fuses.
This is a great 2nd cam hate to lose it . Guess I had a momentary lapse of brains this morning.
Any help wba!!!
Tony
Tony Beazley is offline   Reply With Quote
Old May 15th, 2004, 10:55 PM   #2
Warden
Most (all?) cameras have a fuse, called a fusible link to prevent damage to the camera during power surges etc. However, the fusible link is not user serviceable and needs to be sent to a repair facility. This is a fairly simple repair and does not require factory service. Any authorized service center can do the repair.
Jeff Donald
Carpe Diem
Old May 16th, 2004, 11:40 AM   #3
Jeff
Thanks! Thats good to know. Where would YOU send it too?
Tony
Old May 16th, 2004, 12:26 PM   #4
Warden
You should be able to find a repair agency to do the work in the nearest large city (Nashville, Memphis, Chattanooga, Knoxville, etc.).
Jeff Donald
Carpe Diem
Old May 18th, 2004, 08:42 PM   #5
Tore it down to the main board really is not any fuse to replace way to small for human hands... replace it with a newboard is the only way
Old May 19th, 2004, 07:34 PM   #6
The 'fuses' are normally a semiconductor that looks much like a transistor. No functional difference between a lead-wire fuse and a semiconductor when they burn out. If you had the repair manual, you'd probably be able to ID the component.
Mike Rehmus
Mike Rehmus is offline   Reply
