Printing photos at DVinfo.net
Open DV Discussion
Old May 29th, 2004, 09:53 AM   #1
Printing photos
Newbee here. If I use my Cannon GL2 to capture, firewire to my Avio, how can I print photos on my HP color printer?
Ron Edwards is offline   Reply With Quote
Old May 29th, 2004, 10:11 AM   #2
You'll need a photo editing application. With that, you could resize, adjust colour balance - everything in fact to correct or "creatively interprete" your priceless gems. Failing that, Microsoft usually has a built-in photo-viewer in which you can just click on "print" and choose your output size.
Robin
Old May 29th, 2004, 09:55 PM   #3
Rextilleon
Actually, if you are trying to freeze a frame of video and then output it to your printer, you will need to capture the frame in an NLE. I use Vegas but I believe that the current version of Windowmoviemaker (or whatever it is called) allows you to frame capture. After you have capturecd the frame you will save it as a jpeg and then it can be printed.
David Mintzer is offline   Reply With Quote
Old May 29th, 2004, 11:40 PM   #4
Also, make sure you use the "deinterlace" feature of your photo editor, or you'll get unacceptable results. Finally, remember that the resolution of digital video, while fine for video, is far too limited to produce particularly pleasing results as stills if printed any larger tha 3-1/2" x 5" or so. If you want to go bigger, use a program like Genuine Fractal's Print or Qimage (though Adobe Photoshop's bicubic resampling isn't too bad) -- you won't, of course, get more detail or resolution, but you'll avoid really bad digital artifacts.
Paul Tauger is offline   Reply
