YC and SVHS at DVinfo.net
Open DV Discussion
Old July 27th, 2004, 10:34 AM   #1
YC and SVHS
What is the difference between YC and SVHS? Can the two be Interchangeable?
Glenn Gipson is offline   Reply With Quote
Old July 27th, 2004, 10:54 AM   #2
Warden
S-VHS is a specific format that uses Y/C (separate signal path for Luminance and Chrominance) as part of its specifications. S-VHS was invented by JVC and has a better signal to noise ratio and higher resolution than VHS. It records to a denser magnetic oxide formulation tape, that is the same size (1/2 inch) as VHS. Many components use separate signal paths for Y/C because of better signal to noise ratio and other factors that improve the image.
Jeff Donald
Carpe Diem
Old July 27th, 2004, 11:09 AM   #3
Thanks Jeff, so in a nutshell, I can plug a SVHS output to a Y/C input?
Old July 27th, 2004, 01:13 PM   #4
Ahhh, they are the same. I thought you were saying that.
http://www.studio1productions.com/Ar.../YCConnect.htm
Old July 28th, 2004, 05:04 AM   #5
Note that there are 2 different concepts here.
S-VHS (also called Super-VHS) is a standard for video tape recorders.
Such a tape deck will usually have an S-Video connection out (with Y/C separated).
Thus, as far as I know, S-VHS is a type of VCR, S-video is a connection standard.
So to sum up: S-video and Y/C output are pretty much the same thing, while S-VHS and Y/C are 2 rather different things.
Hans Henrik Bang is offline   Reply With Quote
Old July 28th, 2004, 05:48 AM   #6
Thanks for that clarification...that's why the lady at the electronics store looked at me like I was crazy when I asked for a SVHS cable! She kept insisting that it was a S-Video cable, oh well.
Old July 28th, 2004, 08:41 AM   #7
All analog comsumer VCR's have Y/C internally split and record in "color under" mode. S-VHS and VHS have exactly the same reduced bandwidth for the chroma components. S-VHS allows more resolution for the luma (Y) part.
Andre De Clercq is offline   Reply
