Sony DVMC-DA2 A/D D/A Media Converter at DVinfo.net
Open DV Discussion
Old September 5th, 2004, 07:15 AM   #1
Does anybody have any experience with this device? Any feedback would be highly appreciated. I am planning to connect this device between my old Hi-8 and my DV cam for A/D conversion and direct recording to DV cam (instead of dumping the converted digital signal to a PC first). Many thanks!
Allan Rejoso is offline   Reply With Quote
Old September 5th, 2004, 07:51 AM   #2
Warden
I've not personally used one, but I've heard nothing but good things about the video/audio performance. I heard there is a Lanc controller and on some cameras it may not work properly. If you're using a Sony you'll probably not have any issues, but other cams may be problematic with Lanc control.
Jeff Donald
Carpe Diem
Old September 5th, 2004, 11:57 AM   #3
The 2 works very well with all cameras for transcoding in either direction. Somewhat more problematical about Lanc control (which you don't really need) with non-Sony as Jeff states.
I bought one for the local community college about 4 years ago and it works and works very well.
Mike Rehmus
Old September 6th, 2004, 09:56 AM   #4
Why don't you connect the Hi8 directly to the DVCAM deck/camera and let it do the A/D for you?
VM Productions
Mike Hanlon is offline   Reply With Quote
Old September 6th, 2004, 06:31 PM   #5
Many thanks for all the reply. Actually what I want to know is whether connecting this specific media converter between a Hi8 cam and a Mini DV cam would result in less loss or no loss (conversion) compared to direct recording/transfer from Hi8 cam to Mini DV tape? Or will the result be the same?
Old September 6th, 2004, 10:28 PM   #6
The results will be the same since both methods do the same thing, that is, convert the analog signal to DV. Whether that DV stream is recored onto tape or on a PC hard drive, its the same 1's and 0's.
A third way to do the conversion is with a Digital8 camera. Most (all?) Digital8 cameras convert 8mm or Hi8 to DV.
VM Productions
Old September 7th, 2004, 12:54 AM   #7
Yes, but not all A/D converters or D/A converters are of the same class. I was just thinking perhaps the hardware codec component inside the Sony DA2 is of higher grade/performance compared to what is inside a Mini DV cam, and hopefully would give better results compared to direct transfer from Hi8 to MiniDV.
Thanks again!
Old September 8th, 2004, 04:18 PM   #8
You didn't mention what your DV camera is so it's difficult to gauge. I have a DVMC DA2 and did some comparisons with Miglia and Canopus converters. The Sony was obviously superior. IT's a safe bet for the price range you are looking at and will serve you well.
Old September 8th, 2004, 06:46 PM   #9
I think few people would agree with your comparison of the Sony against the Canopus converter.
I don't own either one in stand-along version although I did buy and use one at the local college. I'm not taking a position but in general, the Canopus converters are considered to be very good.
Nothing wrong with the Sony converter either, I have one of them built into each of my three Canopus DVRex M1 cards
Mike Rehmus
Old September 8th, 2004, 07:05 PM   #10
I only have consumer mini DV cams, a Canon Optura100 and a Panasonic GS100.
The DA2 caught my attention when I saw it in an electronic store in Tokyo for $100.
Old September 8th, 2004, 07:48 PM   #11
The Sony DVMC-DA2 is a steal at $100.
I didn't mean to derogade the Canopus and I didn't give precise information. My comparison was with the low end Canopus ADVC-50 (msrp $219). That was the one I actually had and tested with identical footage against the Sony (MSRP $400). I read many favorable reviews of the Canopus ADVC-100 but I didn't have it to compare.
I can't speak to the Canon Optura 100 or Panasonic GS100 converters. However, my gut says a $400 product whose sole purpose is to do Analog to Digital conversion (and vice versa) probably does a better job of it than a camcorder that also dos conversion and is roughly the same price.
Old September 8th, 2004, 08:02 PM   #12
...I can't speak to the Canon Optura 100 or Panasonic GS100 converters. However, my gut says a $400 product whose sole purpose is to do Analog to Digital conversion (and vice versa) probably does a better job of it than a camcorder that also dos conversion and is roughly the same price.
That's my gut feeling as well especially after I found out the original price of the DA2 in the internet. I guess there's only 1 way to find out :-) Thanks for the replies again!
Old February 4th, 2009, 05:13 AM   #13
analog to digital converter
I have a macbook pro and I want to edit my old 8mm tapes. I understand I need a device to capture the analog signal to turn into a digital signal and in to my mac. Is the Sony dvmc-da2 still available? Are there other devices available?
Waleska Arzuaga is offline   Reply
