Anamorphic and Super 8 at DVinfo.net
Open DV Discussion
Old October 19th, 2004, 08:51 AM   #1
I recently bought a Super 8 camera that has a fixed lens with 58 mm threads -- same as my WD-58 .7 adapter. I screwed it on, and to my surprise, it appears to work just fine. This made me wonder -- why not try a 16:9 adapter? I believe that all the affordable telecine places capture full frame anyway. Century Optics says "no way," but they're very conservative. In the past when I've asked questions about doing something odd with their products (not that odd, get your mind out of the gutter) they always give the same dismissive response. Still, they know their equipment best. Can anybody think of a reason why it wouldn't work? I have one of Century's 16:9 adapters already, but it's a bayonet mount. (Why do they even make those?) Can anybody think of a reason this is a lost cause before I start trolling e-Bay again?
Marco Leavitt is offline   Reply With Quote
Old October 19th, 2004, 10:22 AM   #2
Marco,
If you are going to start trolling ebay, then troll for the right product. You want an anamorphic adapter for your super 8 camera. Yup, they used to make them, along with the anamorphic projector lenses. But I doubt you will be projecting the footage, only telecine transfer.
Here's the problem. When the image is "squeezed" down onto the frame, you will have to "unsqueeze" it in post. Make sure your NLE is up to this, and there is no guarantee that the ratio will be dead on.
have fun
Richard Alvarez is offline   Reply With Quote
Old October 19th, 2004, 11:04 AM   #3
Yeah, I know Pro8 sells some 16:9 adapters that were originally made for super 8, but I was wondering if the adapters made for video cameras by Century, Optex, and Panasonic would also work. It kind of seems like they should, but I wouldn't be surprised if there's an issue here that I'm not aware of.
Old October 19th, 2004, 11:17 AM   #4
Marco,
The target image of super 8 and the Mini DV CCD are slightly different. How different varies from chip to chip and cam to cam. Therefore, no guarantees for the Optex adapters working.
No GUARANTEE mind you, but it might. Cost you a roll of film, processing and transfer to find out.
Old October 19th, 2004, 11:29 AM   #5
No cost except the price of an Optex adapter. :) One problem I can think of is the distance between the lens and the film plane for super 8 and miniDV are probably drastically different too. I don't know if that would be a problem though, as I don't really know anything about optics.
Old October 19th, 2004, 01:44 PM   #6
Over on the super8 filmmaking site, and the super 8 guy's site, they mention using the optex adapters. Don't mention whether or not the conversion is successful, just that it should be possible.
Remember 16:9 post-datees SUper 8 as a format. It is designed for wide-screen television. The old super 8 anamorphic lenses were designed for projection, and I belive the image captured was wider than 16:9. SO... IN THEORY, the 16:9 image from an optex adapter say... out to fit in the target area. But I'm not spending the money on it... you are.
good luck
Old October 20th, 2004, 07:23 AM   #7
If you don't worry too much about what it looks like, you can always just ductape an old anamorphic projector lens on your camera... they go for as little as 100 $ on ebay, and the result is great. You can turn it around and ductape it to your projector lens for projection.
J.
Jan van den Hemel is offline   Reply
